Export/Import dialog window
2067.1
Could it be possible to add an moi.ini option to exclude unwanted (useless) files format from "save as type" list in the dialog window when exporting or saving geometry _and_ put those formats into the one big item labelled "All (*.3ds,*.fbx, etc. - all excluded formats go here)"?
Petr
2067.2 In reply to 2067.1
Hi Petr, the normal convention for a "Save" type dialog is that there is no "All formats" entry, that is only for Open type dialogs.
For save/export the normal practice is to have one entry for each different file type so that it can more clearly show which type of file is being written.
With a combined "All" one for save (open is different), it is not clear anymore which file type out of that combined batch you want to use for creating the new file.
So that one particular part about having the "one big item" for save is not really very feasible.
But I have added in an exclusion system for the next beta so you can have some control over the list of file types.
The way it works is a new entry in moi.ini:
[FileDialog]
ExcludeFileTypes=FBX,3DS
The types that you specify in that list will not be displayed as individual items in the type drop-downs on the Save or Open type dialogs.
However, even if a format is excluded from the types drop-down list, you can still export to its format by typing in the file extension directly in the filename.
That's a shortcut that you can use normally as well - you actually don't need to drop down that "Save as type" list at all if you type in the name of the file extension when you are typing in the name of the file. The way MoI is set up, if you type in a file extension directly, that will control the file type that is written regardless of what that "Save as type" dropdown says.
So that is another way to deal with a longer list - just type what you want and don't ever drop down the list at all.
Also when you exclude a file name with the above new moi.ini method, only its individual entry will be removed from the list, it will still be used for the "All supported" entry for Open.
Does that seem like it will cover what you wanted here?
2067.3 In reply to 2067.2
Yup. That's it. Thanks.
That one big item for save was actually considered as a "marker" that there are another formats in addition to listed ones.
Petr
2067.4 In reply to 2067.3
Hi Petr,
> listed ones.
Hmmm, but I don't know what I should do if you were to pick that item... On regular items it will do things like switch the file extension for you when you switch between items.
I figure that since you have to list the ones that you want to exclude in moi.ini, there isn't much chance that can happen by accident. So hopefully you will know that there are additional formats since you were the one that screened them out! :)
2067.5 In reply to 2067.4
Hi Michael, I guess the word "marker" wasn't proper one. I just meant the list of all items would be only a visual feedback so that I could see all available formats to export/save a geometry. -Petr
2067.6
This certainly was a good idea cause there are a lot of formats I don't use - nice!
-Will
