Lettering
All  1-2  3-4
2063.3 In reply to 2063.2
Solved the problem, Michael, I'm happy to say.
I had the mesh angle turned down to a very low value. I also swithed off "detail to inflections" and now the fillets happen super fast. Nice :)
Here's another thing I found:
With some letters, S in particlar, if I fillet the vertical edges, then the top face will not fillet. It would probably be better to fillet the original 2d curves before extrusion.
EDIT I withdraw this comment. Problem solved by slightly reducing the fillet radius
By the way, it's great to be able to turn hidden lines on and off from the view menu. I don't think that feature was there in v1. And the C-plane feature will definitely come in useful.
EDITED: 11 Oct 2008 by STEEVE
2063.4 In reply to 2063.3
Hi Steve, sounds like you have got things under control now!
> was there in v1.
Thanks, yup that is new for v2. I'll probably be putting various other view options that you may want to turn on or off relatively frequently over there where you can get at them a bit easier, rather than only on the Options dialog.
Show messages: All  1-2  3-4
