About SKP format
All  1-9  10-15
2058.10 In reply to 2058.8
> If you draw a curve (alone) then copy it, then move it , then
> replace it at the same place I believe the 2 curves are merged!
That may be correct, but here you are talking about drawing an edge in SketchUp - when MoI writes data to a SketchUp file it does not run in an identical way as when you are drawing things in SketchUp, different code is running in these different cases.
I would probably need to do all that analysis myself and also another complication is that it could be pretty easy for a surface edge to have a different number of tessellated points in it than a stand-alone curve that is tessellated, since the surface edge also has points added into it where the UV polygon grid of the surface intersects it.
So it may be somewhat difficult for me to achieve any fully automatic "stacked up curve" removal.
I guess it could be possible for me to do it by a doing an in-depth comparison of every curve to every edge to look for duplicates in the original model data before doing any tessellation. That kind of full model comparison is potentially a very time consuming thing and has to be done very carefully so as not to take a large amount of time, so it is not something that I really will be able to do right now.
That's why I am using this method of not exporting curves by default if you do a SaveAs and have surfaces and curves together, that is probably safest to avoid "stacked up" type duplicated curves and edges which would probably be somewhat difficult to eliminate in SketchUp.
But if you would like to have all curves written at the same time as writing surface/solid objects, that will still be possible by selecting them all and using the Export command from MoI.
2058.11 In reply to 2058.10
Hi All,
As a long time user of SU and MoI, I'm just curious about why you guys would move a model from MoI to SU?
Would it be for "dressing up" purposes, ie, adding materials and setting up scenes for rendering?
2058.12 In reply to 2058.11
Hi Steve,
Adding objects that are difficult to construct in SketchUp, align them, Boolean operations that are limited in SU, double cutting openings in walls from views, are few examples.
Regards,
George
2058.13 In reply to 2058.11
@ Steve
Another big reason is that ketchup is the more easy free box modeling prog and becomes more and more powerful!
And it has behind it the Empire's Google! And the version 7 is coming soon ;)
Moi + ketchy = the zen modeling! in the first image Moi can be help because that is some rustic method but efficient ;)
By Silver Shadow
http://www.sketchucation.com/forums/scf/viewtopic.php?f=81&t=12513 Making of
here modeling is only ketchy ;) (render is not ketchy)
EDITED: 12 Oct 2008 by PILOU
2058.14 In reply to 2058.12
Sorry George, I didn't make myself clear!
What I mean is if you build a model in MoI with its arguably superior modeling capabilities, why would you then export it to SU?
Just curious
Steve
2058.15 In reply to 2058.13
Yes, Pilou, I know you are a big fan of ketchup:)
That model by silvershadow is pretty amazing. That guy has a lot of free time!!
I can see that a good workflow could be
build model in MoI
export to SU
add materials
export to KT
build scene
render
Because of my arch background, I export from MoI to Cycas which (apart from being a great arch application) has a good, easy portal to povray
Show messages: All  1-9  10-15
