Simplify lines or arcs
 1-19  20-25
2051.20 In reply to 2051.15
>>You may be interested in this method of doing a tapered style extrude:
http://moi3d.com/forum/index.php?webtag=MOI&msg=941.5
In relation to this thread I was just wondering now that we have direct math input in MoI, you mentioned that angle input is in radians, the formula you used in that particular thread to create tapers, is 'Offset dist = Height x Tan( angle )' which is used often in mech eng and nice and easy to input into MoI, but to convert to radians which is: degrees X pi/180 it's a bit annoying is there any way to change the angle input in MoI to degrees ?
2051.21 In reply to 2051.20
Hi Danny, re: math expressions angle input in degrees,
Yeah I think that makes sense since this area is for typing stuff in.
It is pretty easy to tweak that and I have set this up now for the next beta. All the trig functions (tan, sin, cos, atan2, atan, asin, acos) will now take or return angle values in degrees with the next beta.
If you do need to use radians for some reason, the radians versions are all still present with an underscore preceding them, like: _cos(PI) that keeps radians input still easy to use if someone feels the urge to type in values in radians... :)
2051.22 In reply to 2051.21
Thanks Michael,
Also, it's good that you kept the radians side of things, I do sometimes have that urge to calculate things in radians, usually standing on my head drinking an ice cold coke through my nose :D
2051.23 In reply to 2051.19
Thanks Brian
When you say "the standard 3d letters"
did they come from inside MoI or outside?
Steve
2051.24 In reply to 2051.23
Steve
Yes. The standard letter text in the solids.
BUT
Am I pe-empting you with this question about fillets?
Image and file.
Brian
EDITED: 31 Dec 2008 by BWTR
2051.25 In reply to 2051.24
Brian,
I'm embarrased to say that I had never noticed the letters before!
It just proves that you see what you want to see!
Yes that is the sort of look I am after with the filleting...I've continued this as a new topic.
Steve
Show messages:  1-19  20-25
