Filleting
 1-2  3-22  23-25
2048.3 In reply to 2048.2
Thanks Michael.
I have been through that Help Manual and --maybe--something is not sinking in?--or, I am expecting something outside the limits?
Sorry to worry you
Brian
EDITED: 15 Nov 2008 by BWTR
2048.4 In reply to 2048.3
Brian,
Not that I am a pro, but the front edge of your main airfoil seems to intersect the fuselage at a very tight angle, I suspect the filet radius on that kind of geometry would be the issue. Dont forget that filets are a way to save time for designers, but at the end of the day, if you are actually planning on using this model to make an aircraft, you probably want to fully control the interface between those two b-reps so that you can better control the aerodynamics of that structure. If your just doing this for fun, try opening up that front interface angle and reducing your filet radius.
Hope this helps,
Adam.
2048.5 In reply to 2048.4
Adam
Thanks for the response but "nomenclature" problems---
"----interface between those two b-reps" ???
"--try opening up that "front interface angle"???
Is my age showing?
Brian
PS----YES, I am doing it for FUN!
I think I deserve a design medal when compared to the Spitfires I used to draw in my school books in the early 1940s!
EDITED: 7 Oct 2008 by BWTR
2048.6 In reply to 2048.1
Hi Brian, thanks for posting the model, that really helps to see what is going on.
One thing that is really going to mess up the filleting in this situation is the back edge of the wing which already tries to come in kind of smooth to the main body, it is at a very very shallow angle, kind of practically pre-filleted already:
When you want to set up something for filleting, it will actually tend to mess it up a lot if your surfaces are partly blending together as if they were filleted already, that's kind of what you've got in the above situation.
Instead, the spot that you want to fillet should have the surfaces meeting at more of a sharp crease, kind of a more distinct edge rather than partially smooth already.
More like this for example:
Then fillet will work a lot better on the more distinct edge:
Basically if the edge to be filleted has surfaces that are already partially smooth together, that creates a difficult situation for it.
So don't try to make it so smooth initially, you can make it approach it somewhat but not to the degree at the spot where I showed above. Instead let that area be more of a sharp edge and let the fillet smooth it out instead of trying to build it partially smooth already.
Hope this helps!
2048.7 In reply to 2048.6
Thanks as usual Michael.
The thing is that I didnt "---- try to make it so smooth initially"
The design concept well---sort of have happened "visually." When (I) get those concepts it's very hard
to visualise in depth the problems that may occur later (?obviously with a lot of my work).
Is something similar a problem with the tail? I got the vertical part to fillet!
Brian
PS---
Doing a sweep approach is just so simple ---but!
EDITED: 31 Dec 2008 by BWTR
2048.8 In reply to 2048.7
Hi Brian, the tail is something different.
It is definitely meeting at a good angle, not at all similar to that other problem.
It looks like what happened there is that you didn't quite push the tail through the body quite far enough for it to punch all the way through, here is a view down into the inside of that section:
Notice that area looks like it did not fully punch through the outside surface:
I think that one would probably fillet fine if those parts got pushed a little bit more in when they were booleaned so they fully punched through the outer skin instead of only partially, although there is not very much room left there until it runs into the fillet on the vertical part.
2048.9 In reply to 2048.8
Hi Brian, actually there is one other issue with that tail as well, which is that it isn't very good to try and fillet a very thin "knife edge" type situation like that.
You can see that the vertical section did fillet, but it did not produce a very good result in the back:
It is tough for the filleter to produce a nice corner in such a sharply angled "knife edge" situation like that.
If you want to fillet that well, it would probably be necessary to first fillet that very sharp edge so that it was a slightly rounded edge first (probably actually best to put a small rounded piece in there early on from the initial sweep actually), and then boolean the pieces together, then do a fillet where they met and it would then not have that "knife edge corner patch" type issue.
Filleting things that come to a very sharp angle generally can cause problems for MoI's filleter. You may have some better luck with those particular knife-edged ones in ViaCAD instead of MoI.
EDITED: 7 Oct 2008 by MICHAEL GIBSON
2048.10 In reply to 2048.9
Ahhhhh!
Thanks Michael.
Brian
2048.11 In reply to 2048.10
Hello
As you're talking about it, will Viacad (pro) be a better alternative than rhino to extend my actuall MoI toolset ?
For the moment I switch time to time to rhino for :
- the surface continuity option with the sweep or network tool
- the patch tool
- sometimes to use the sweep tool when Moi's distribution failed to give a nice result.
Of course Rhino do the right job for this, but it's a bit expensive for the 3 tools I use.
As I'm still a noob in this cad world, I don't really get the difference between viacad and Moi/Rhino nurbs library.
You suggest to give a try to viacad, is difference so huge about filleting stuff. It happends in some case that I'm stuck
with some fillets, even if it happends less and less. And most of the time if a fillet failed in MoI, Rhino will not really help either.
Viacad pro seems to have some nice tools in :
http://www.punchcad.com/products/viacadpro_features.htm
- Bending Along Curve ... well why not (are they using construction history to handle this ?)
- Offset Surfaces : would it be a little better than MoI's one ?
- Skin with Guide Curves ... don't really get the concept
- Surface Matching ... sounds cool, and seems to be performed after the surface creation, not sure if it will work on imported models
- Tangent Covers ... well seems to be a patch tool right ?
Would like to have an advice about it, the workflow seems really different from MoI and I'm affraid by the learning curve :S
2048.12 In reply to 2048.11
Michael
Sorry for being a pain.
I went through everything I thought I had learnt.
I tried all sorts of options.
And still can not get a fillet.
When you can spare a moment please.
Brian
2048.13 In reply to 2048.12
Not an expert here,
But I suspect that this shading change result from a lost of continuity in the wing, and that give some trouble to build the fillet.
Looking at the profile curve of the wing, there is indeed probably a discontinuity in this area, the 3 points (red lines) should fit on one line.
So with the help guide, I draw a line going throuth the 2 first curve control points
and move the third one on the same line
I don't really get how you build the wings, so I reuse the 3 curves in the file, using the network ... seems to give something pretty close from
the original one
Now it's time to clean this part, separate everyting and delete the wing
Select the body and click on the show points command
Select the hole edge curve
and hit delete.
rejoin everything.
Don't forget to cap the wing with the make planar command
Booelan union
Fillet should work !
Sorry for all the spelling mistakes, did it really fast ;)
EDITED: 3 Dec 2015 by PAQ
@Pac
In France Viacad is here ! http://www.cobright.fr/
Many video in French (more for Shark ) but it's same prog for basic functions!
Article on DVF http://www.3dvf.com/modules/publish/Logiciels_1895_1.html
The more important! Comparaison between all products!
http://www.punchcad.com/products/PunchCADFeatureCompareV1.pdf
EDITED: 8 Oct 2008 by PILOU
2048.15 In reply to 2048.14
Thanks Poilou for the the reference, the 3dvf review was instructive !
So I did a quick try in viacad, and the fact that I wasn't able to cross over the red line make me thing that was maybe the problem in MoI too.
Indeed I was able to come very close from what viacad can do on this particular shape -> 0.425 was the limit I find for this wing.
EDITED: 3 Feb 2010 by PAQ
2048.16 In reply to 2048.15
Heurm ... round 2 ... Via was able to do a little bit larger, but seems to add an extra edge too Oo
I think I'll stop here as :
-I'm talking to myself
-I'm starting to be a little bit lost too :P
2048.17 In reply to 2048.11
Hi PaQ,
Well, it all depends on what you want to do.
Viacad would be better for things along the "Mechanical CAD" or "Solid modeling" direction (for example, shelling & fillets), while Rhino would be better for stuff along the "Industrial Design" and "Surface styling" type direction (flowing surface type stuff).
Neither one really covers the other area very well.
> - the patch tool
This is the kind of surfacing stuff that would do better in Rhino. I think that some of this is present in ViaCAD as well, but is kind of like an afterthought over there and not really set up very well (in my opinion).
Well, they all use different libraries. So they tend to have different sets of bugs and different weak and strong areas.
The one used by ViaCAD is used by many "parametric solid modeling" / Mechanical CAD programs though and has a lot more development time spent in the areas of filleting and shelling in particular.
No, it is not very likely that Rhino will help out for filleting. There probably are a few cases where Rhino could do a fillet where MoI had problems, but much more of the time I think it is the other way around where MoI handles fillets that Rhino has problems with.
And Rhino does not currently even have a shell function at all, so it is zero help for that. Shelling is a pretty good area of ViaCAD though.
No, they use some code in the ACIS "Deformable modeling" library to do this, being able to bend things depends on a bunch of code that calculates the bent object, having construction history doesn't really have anything to do with it.
But this is an area that would probably be handled better by Rhino, that have a nice set of new tools in v4 for deforming objects.
Yup, this would be a strong area of ViaCAD.
I think it is their version of 2-rail sweep.
Should work fine with imported surfaces, but probably again I'd go for Rhino with this kind of "surface styling" oriented task.
I think so.
Yeah, one downside of ViaCAD is that it is kind of based off of an older line of programs, it has a lot of legacy remnants in the way that it works. It would probably take a bit to get used to actually creating things from scratch in it.
I'd generally recommend to use it mostly for filleting and shelling pieces, if you just focus on those particular tools that would probably get the optimal use out of it with least frustration.
2048.18 In reply to 2048.12
Hi Brian, no problem. I'm sorry that filleting gives so much trouble it is unfortunately a quite sensitive and complex calculation involved with it.
It looks like PaQ has given some great steps above there for how to make a more totally "fillet friendly" shape.
I took a look at your model, and it actually your existing model seems to fillet ok for me at a small radius value like radius of 0.2 .
So after doing that, here is a look at that front edge that PaQ was referring to:
Zooming in:
You can see there that since those pieces do not meet smoothly, it forces the filleter to try and splice in a kind of corner connection piece between them. Making those smooth to one another will eliminate that and helps makes a more simple fillet structure there, that can help.
Then the other thing is notice how this "seam" edge is pretty close here:
Probably the #1 problem with fillets currently is that it will not cross a nearby edge like that, it will only approach it. So currently it tends to be best to make your part actually cut through the seam instead of come close to it, that avoids that issue.
2048.19 In reply to 2048.18
PaQ, Michael
Thanks for all that brilliant help.
WOW!
The study/think cap is going to be busy again today.
Brian
2048.20 In reply to 2048.19
As a PS side note!
I saved the MoI file as an OBJ file and took it into a polly modeller to try filleting there.@#%&**
MoI is GREAT!
Brian
2048.21
You're welcome Brian, I'm happy if it was helpfull somehow :)
Thanks Michael for the little nurbs lesson here.
I don't think I will invest to much time to learn viacad if it's only to use it 3 times/month just for some fillet issue ... but I will play with it a little bit during the evaluation time.
I can't wait to see how MoI will grow too :o)
2048.22 In reply to 2048.21
Hi PaQ - the other kind of very different area that ViaCAD is good at is in sort of blueprint style 2D drafting. I think it's got stuff like generation of 2D plans from a 3D model, and easy to use dimensioning tools.
But probably for your kind of work that would not really come into play much.
Rhino has some of that stuff as well, but that is a pretty good area for ViaCAD also.
Show messages:  1-2  3-22  23-25
