FBX welding test
All  1-10  11-19
2045.11 In reply to 2045.10
Hi Brian, N-gons can tend to be one of the more difficult areas.
For most systems to display the n-gon will require triangulating it, and it is a pretty difficult task to make a good quality triangulator that will work correctly on complex n-gons.
Furthermore until MoI came along it was not very typical to get a whole lot of n-gons in transferred data, since there are no other CAD programs that will generate them from CAD data - that is a unique feature that has been introduced by MoI. So that means that typically programs have not been tested quite as much during their development with complex n-gons.
That can add a few wrinkles into the mix.
If you run into these problems then you can use the Quads & Triangles option to break N-gons into the more typical quad and triangle type polygon output when exporting from MoI, that is a more "well worn" and well tested type of data.
But the n-gon export is nice when the receiving program can deal with it well, since it keeps your mesh wireframe more orderly and clean.
For 3D coat's particular use though like I mentioned it probably wants to have a certain style of mesh structure with more finely diced polygons instead of big broad polygons of any type, whether n-gons or not.
2045.12 In reply to 2045.9
curious curious because I have all versions of Wings!
Your 0.99.02 and 0.99.04 (the last! )
Maybe Seems there is something with the name of the file
in your folder, "TestFBXWeld1.fbx" appears in the wings selection windows, but when I troncate it the .fbx, it's appears TestFBXWeld1 in the window selection and TestFBXWeld1.fbx in the wings3D message error
as you had writed in fact TestFBXWeld1.fbx.fbx ???
but even with that, that's is "Unable to read the file"
and more curious I had loaded your first FBX test in the past with success!
2045.13 In reply to 2045.12
Hi Pilou, that's strange, I don't know why it won't work for you.
I happened to put the TestFBXWeld1.fbx file right at the c:\ root folder, maybe for some reason Wings does not like to handle a folder where you have placed this particular file. Does it make any difference if you move the file to be directly under c:\ and try to import it from there?
2045.14 In reply to 2045.13
YESSSSSSSSSS!
It was that! I must put the files inside the root of the folder of WINGS 3D!!! (so a bug in wings ;)
Works fine with Version 0.99.04 :)
House and plane!
A scale must be made at the import because grid is some little ;)
Scaling is possible in the Menu Import of FBX Wings3D 0.1 by default, 0.01 will be perfect! :)
EDITED: 6 Oct 2008 by PILOU
2045.15 In reply to 2045.9
< The other file, TestFBXWeld2.fbx is a high polygon count file, Wings seems to be rather slow at handling that one so that one did not work quite as smoothly for me, which looks like something that would need to be tuned up in Wings. But the first one seems fine.
No problem for me on my very old comput!
After 2 levels of Smooth :)
2045.16 In reply to 2045.14
Hi Pilou, yes that seems like a bug with Wings.
I just tested over here, and for me it seems to actually work ok for other folders as well, like "My documents", etc...
If you would like to test it some more to give them a good bug report, I bet it has something to do with having some French language characters in the folder name that did not work.
2045.17 In reply to 2045.16
< French language characters in the folder name that did not work
Possible, that is the same problem with Kerkythea!
No accent in any Folder, names, path!!!
And must be in a particular Folder "Model"!
2045.18 In reply to 2045.17
Hi Pilou, if you get a chance to give a bug report to the Wings people, it would probably help them if you could give them an example of the kind of folder name with an accent in it that does not work.
Also, one other note that you could pass on to them - let them know that the FBX library seems to want to take a file name as a UTF-8 encoded string, not one encoded with the current code page. The FBX documentation is not at all clear about this.
2045.19 In reply to 2045.18
Ok I will send that on the Wings3D forum ;)
Done !
Waiting the answer :)
EDITED: 7 Oct 2008 by PILOU
Show messages: All  1-10  11-19
