Modelling help req'd - windshield
 1-7  8-27  28
2020.8
Frenchy and Lyes thanks very much for taking the time to respond and have a go at it.
Michael, yep I fully understand what your saying. The problem I have with creating this shape is that I'm trying to model this windscreen accurately. It is not for a fantasy object but a real aircraft. While Lyes solution at first glance seems to be a good one it is not giving me the flat windscreen that I want to achieve but a curved windscreen that follows contours of canopy shape. In the side view shown it needs be straight line and not curved. Cutting out the windscreen and sweeping it again is only restoring the original shape So Frenchy's very first post is closer to what I want to achieve (although not ideal) due to the extra flow line added to the shape associated with the sharp corner which will require lots of tidy up in the polygon mesh generated.
I guess this is just another limitation of working with nurbs, that I have to accept.
EDITED: 28 Sep 2008 by KEVJON
Size: 32.3 KB, Downloaded: 10 times, Dimensions: 450x307px
2020.9 In reply to 2020.8
Not very sure that I actually used any of the forgoing methods exactly?
Alternatives/alternatives!
Brian
EDITED: 31 Dec 2008 by BWTR
2020.10 In reply to 2020.9
I wonder why my wife locks the doors so I can not get out and wander the streets!??
Brian
2020.11 In reply to 2020.8
Hi Kevin, sorry I missed your last post here.
If I understand correctly, I would still recommend using the basic approach that was shown there of building a larger and more simple structured surface first and then cutting it.
But if you want to have a perfectly straight line as viewed from the side view, instead of cutting from a shape in the Top, draw a line on the side and use that as the cutting object.
Here are some visual steps.
First sweep the larger shape same as lyes showed - this is with the 2 bottom parts as the rails and the central part as a scaling rail. That produces this:
Now switch to the side view and draw the straight line that you want to have as your exact straight line profile, like this:
You can now select the sweep, and then use either Edit/Trim or Construct/Boolean/Difference to cut the sweep by the line. Here I used boolean difference which cut the sweep into 2 pieces:
Delete that interior part that has the curved region that you don't want to keep, that leaves you with this:
As viewed from the side that edge is completely flat:
Now to surface that interior piece - if I understand you correctly you do not want to have any curvature there, so instead of sweeping a curved profile along it, draw a line at the bottom of it between the ends there:
Then select the line and the edge and use Construct / Planar to build a planar surface there:
The result is attached here as Canopy_flat_side.zip
Is that the result that you were looking for? If not I may need some more details.
2020.12 In reply to 2020.11
Hi Michael
Why in your model there are crips?
Could you have shell now?
Curious in my model I have a more thickness of lines?? I don't know why?
Ps Of course I have not the Plan Surface of the little part inside my previous model ;)
2020.13 In reply to 2020.12
That's a display artifact that can happen if you have the mesh density set to lower. With a smaller number of polygons the triangle structure can be revealed.
If you want to eliminate those, go to Options / View / Meshing parameters, and check the "Add detail to inflections" option, which will create a denser mesh and should eliminate the visible triangles there - does that solve the problem for you?
Basically though that is not really any defect in the surface at all, it is just a display issue only.
I don't think it will shell properly - there tends to be a problem with matching up corners when attempting to shell an open surface that is made up of multiple pieces that have sharp corners in them.
Shell will tend to work best when used on single surfaces that are all smooth, or it can handle corners better when you shell a closed solid. A non-solid that has corners can be problematic, there was some discussion on this previously here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=133.11
I believe this case will run into the same issue as in that link, with the surface extensions not being done properly.
For cases like this you may need to use the Offset command to construct some individual offset surfaces to build the thickened pieces manually. Or possibly a good approach would be to use Edit/Separate to break the model into individual surfaces, and then use Shell on the separate surfaces to get some pieces to work with.
Or actually now that I think about it some more probably the best option would be to shell the original sweep surface before cutting it.
Probably you've got some duplicated pieces there, or duplicated some of the edge curves as new separate curve objects.
When you have several curve objects stacked on top of each other they will get a bit darker like that.
2020.14
Thanks Michael,
That is a really good solution to the problem. Just trying to figure out what shape the green line needs to be so my windscreen shape matches the real aircraft when the line on the side is cut is the only problem. I guess it is just a trial and error process.
~Kevin~
Size: 35.9 KB, Downloaded: 9 times, Dimensions: 671x421px
2020.15 In reply to 2020.14
Hi Kevin, yeah you may need to edit that curve to tweak the result to what you want.
You can use history to help with that - currently history will be broken after you do the trim or boolean operation but you can use it immediately after you do the sweep to help fine tune the results.
The way that it works is just after you do the sweep, select that center curve and turn on its control points by Edit/Show pts. When you move the curve's points around the sweep will update so you can adjust the shape of the curve and see right away what the effect is on the sweep. You have to just visualize what the result of the cut is though, that part does not work with history yet but I do want to improve this in the future.
I mean you still need to edit points for the NURBS construction method, it is just that the focus is a lot more on editing points of 2D curves rather than editing points of a 3D cage mesh.
2020.16 In reply to 2020.14
Then another piece is if you want to blend off the sharp edge you can put a fillet on this edge:
I'm not quite sure if you actually wanted a totally flat plane in there or not though.
2020.17 In reply to 2020.16
Also Pilou, if you wish to shell this it will shell more easily if you fillet that edge. Shelling of smooth pieces tends to reduce a lot of problems.
2020.18 In reply to 2020.13
< Artefact
I had a premonition about that :)
< does that solve the problem for you? "Add detail to inflections"...
Surely but as I am always at same default regulate, "add details" disable, it's the same for your model so pertubating :)
Because mine has not!
< Probably you've got some duplicated
He he
It was just the start generator curve of the original of Kevin's model so resolved :)
And yes with the fillet Shell is some better!
EDITED: 2 Oct 2008 by PILOU
2020.19 In reply to 2020.15
This is the problem working with nurbs when you are trying to model stuff that looks like the real thing and you have to define the overall shape first and then do booleans rather than doing it the way I was on the first post of this thread which is define the shape of the object with curves (get that part looking right) and then create the surfaces.
For example the fuselage of the F9F panther (see pic) is quite simple (perfect circle) but trying to define the shape of the cross section curves so that when you boolean out the cockpit opening so it is the right shape and size is a bit of geometric puzzle due to the subtle curvature extending from the fuselage up to underside of the canopy (particularily around the rear of the canopy).
It very slight (see photo) but thanks for showing the idea of how to address this area.
Size: 112.2 KB, Downloaded: 35 times, Dimensions: 600x450px
2020.20 In reply to 2020.19
For the canopy area as you mention, you could build the shape first, then cut out your inside section.
2020.21 In reply to 2020.20
Thanks BurrMan
The blend of the fuselage into the cockpit is quite a soft and subtle which needs to be handled by a variable fillet radius. As MoI does'nt have the option you would need to create it manually via a swept surface. There is also a subtle chine along the spine of the fuselage which adds to the complexity of shape.
I'll post up my attempt at it over the next couple of days when I have time to work on it. I always try and minimise surface joins as much as possible as they often result in messy mesh joints that need to be cleaned up in the polymodeller.
2020.22 In reply to 2020.21
Look forward to the outcome. Details, details! :)
2020.23 In reply to 2020.22
Thats kindof what I was getting at. Mine is kindof cheesy but if you know the direct shape you want , it should be fairly simple.
2020.24 In reply to 2020.23
MoI's surface mesher is second to none! Looking forward to a great model!
2020.25 In reply to 2020.23
BurrMann
Here is my first attempt tackling the shape which is the logical way to model such a thing. But I get pinching at the back of the cockpit due to the hard joint in my curves.
As Michael has stated with nurbs my method above is flawed because with nurbs it is best to do the overall shape then cut out the cockpit opening. However the problem with that approach is what shape do all my cross sections need to be so that when the cockpit is cutout it looks right in side and plan view ?
So my next attempt will be the way you show which results in more surface joins and more messy mesh joins but looks like it might be the only way. However creating the blends from the fuselage to the canopy will probably still result in the pinching shown above but I'll give it a go anyway.
~Kevin~
2020.26 In reply to 2020.19
Hi Kevin, thanks for the image - it is a bit small though and only from one angle.
Since you're trying to very exactly match the profile from different directions, do you have images zoomed in on just the canopy from different directions (like front view, side view, etc..) ?
That would definitely help otherwise it will probably be many more rounds of just trying different shapes that then you'll say are not quite exactly right...
Maybe NURBS is just not a good fit for your project or the way that you like to work.
Trying to do contoured surfaces tends to be a more difficult area since they are not as totally clearly defined by side profiles as a purely mechanical shape. So it is pretty natural that things like aircraft and automobiles are some of the more difficult shapes to work on.
2020.27 In reply to 2020.25
Hi Kevin,
Could you please post the .3dm model file and also those blueprint background images? That should help...
Show messages:  1-7  8-27  28
