CPlane Question
All  1-2  3-5
1994.3 In reply to 1994.2
What I should of said was 'savable' or incorporated in the object organisation stuff ?
Saveable as in, once you've positioned a Cplane you hit the Cplane save button and it leaves like a ghost or witness triad so if you have to go back to that work plane you hit the Cplane command and just pick the ghost triad and it automatically orients it self to that saved position.
1994.4
Michael
I really like the way you've implement the cplane in Moi.
It makes modelling so much easier having that option available.
~Kevin~
1994.5 In reply to 1994.3
Hi Danny, that sounds like a good method to have pickable triads to go back to a saved construction plane. I was originally thinking about more of a named system where you could save a cplane as a named item and see it on a list and pick it there. I suppose a good way could be to do both, have it on a list or also pickable in the viewport at the same time when in the "Restore cplane" type mode.
I'm going to wait a while before trying to dig into this area, it is possible that a list of cplanes may fit in pretty well with the object organization toolset, as something that shows up in the browser tree view thing. It is probably a good idea to see how that turns out first before trying to incorporate a saved cplane list type thing.
There may be some good potential for it to just take one click to activate a saved cplane if it shows up in the browser window (by clicking on it in the browser list), rather than needing to go into a special restore type mode.
Show messages: All  1-2  3-5
