CNC contours parts from 3D models
All  1-10  11-19
1990.11 In reply to 1990.10
Thanks Ray !. I'am definitively writing in french and translate after with google translation. After working 8 hours a day with google Sketchup, i 'm going to speak with google translation now: i'am going to make google dreams !.
Bye,
Pierre.
EDITED: 27 Sep 2008 by PIERREARCHI
1990.12 In reply to 1990.6
Bonjour Pierre,
> Could we have a "copy a planar curve from its current 3D location
> onto a flat plane" tool for the next beta. It will be enought for me
> and my job !.
I think there will be an Orient tool that will help with generally moving objects from one position to align with another, but I have not completed it yet so I'm not completely sure how it will work. But I think it will probably do this job.
> A question to go ahead : In this tool, Do you think is it
> possible to make changes on the projection (projected
> curve on flat plane) and have modifications linked to the
> original 3d position curve (feedback option).
Unfortunately that is a difficult task that would require a very much larger amount of work, so it is not likely that I'll be able to add that in to this tool at least not for quite a while.
I do want to make a better and deeper history update function, but here you are talking about the reverse type operation of editing the results and having the original update - the main focus for history updating is to update original objects and have the results update instead.
If you need to do this kind of a function, maybe one of the parametric solid modelers that are focused on this kind of stuff may be a better choice for you than MoI.
1990.13 In reply to 1990.11
Your english is not so bad. The google translation was by far, for me, more confusing!
Just a note.
Burr
1990.14 In reply to 1990.12
Hello Michael,
i know you are doing your best to satisfy all of us (MOI community)!.
Concerning the orient tool , will it be possible :
- to select differents contours together and orient them on choosed plan in one operation, one click .?
- an option to project contours only on ground plan ?
Pierre.
PS : This tool could change a lot my way of working (i will not have to draw again the same parts in another cnc software (vcarve) !!! Hours won !) that's why i ask too much questions about it !.
EDITED: 29 Sep 2008 by PIERREARCHI
1990.15 In reply to 1990.14
Hi Pierre, again I'm sorry MoI is just not currently targeted at being a CNC curve processing program, it is focused on doing modeling operations and you will probably need to find a different program that is focused on these particular kinds of CNC processing tasks instead of MoI, at least until the future at some point when someone else may be able to add more CNC focused commands into MoI as a plugin.
Given all the things that you really want it to do such as labeling, etc... I just don't think that I will be able to get anywhere close to the stuff that you have been asking about anytime soon.
I'm not quite sure, I have not been able to work on the orient tool yet so I'm not quite sure yet exactly how it will turn out. But probably this will only work if the contours are all together on the same plane.
Maybe it will be possible for me to add in enough stuff so that a custom script command can be made that will be able to use some of the re-orienting tools in a more automated process like you want, but I'm not quite sure yet how much work that would take.
Could you please describe this one some more? You can use the Construct / Curve / Project command to project a curve on to a surface, does that help any?
1990.16 In reply to 1990.15
Hello Michael,
I don't want to make MOI a CNC software but open it to an another (customers) community with just a nice script !
Two "automatics" actions in the same script :
- 1 The Z of the contour (or a contours group) in space 3D selected will become Z=0. (is What i call "on the ground plane" )
- 2 Contour (or a contours group) selected in space will be re-oriented to became "flat"(without dimensions distorsions) on the X and Y plan.
That' all !. If someone could explain the job with the existing project tool, it is ok for me !. i don't have good results with curve/projection tool.
Bye,
Pierre.
PS : Pour Frenchy Pilou : Il s'agit à travers un script et de la selection d'un contours dans l'espace 3D de le projeter à plat sur le plan XY avec un Z=O !. Ce n'est pas la mer à boire pour rassembler la communauté CNC autour de MOI...non ?
EDITED: 30 Sep 2008 by PIERREARCHI
1990.17 In reply to 1990.16
With only one selection 2 clicks, one rotation seems you obtain that you want ?
Seems a script can do that? (Rotate all selection, and the Scale 1D will be same result)
EDITED: 30 Sep 2008 by PILOU
1990.18 In reply to 1990.17
Thanks Frenchy Pilou for this illustration !.
Some détails concerning the script close to your proposition :
- In fact, i just need contours to be projected, not surfaces.
- Possibility to rotate a group of contours in the same time : interest of a script.
- Possibility to rotate on 0,X,Y plane(ground) contours which are not in the X,Z or Y,Z plan (your exemple show object in the Y,Z plan, axes behind object make me think about it).
Bye,
Pierre.
PS : I could pay for this script if someone is interested !(around 50 Euros ).
EDITED: 1 Oct 2008 by PIERREARCHI
1990.19 In reply to 1990.18
In fact when you have your contours any rotates axis toward any plan takes one second by hands ;
No need script for that ;)
I am not sure of the Scale 1D ! I suppose vertices are stacked on a same positions but always exist?
Maybe this can be produce problem?
Depending of what is the folowing next step?
Show messages: All  1-10  11-19
