move scale roate f BAckground images
All  1-8  9-15
1982.9 In reply to 1982.7
Hi okapi, how about something like this:
That will let you pick 4 points to do image registration - you pick a base point and reference point on the image (you'll probably want to zoom in there, I didn't do that to keep this screen capture small), then pick a target base point and target reference point snapped on to your geometry.
It will then do a combination of move, rotate, and scale to make the image aligned and sized to the right amount to align with that geometry.
1982.10 In reply to 1982.9
this is great!
This is even better than what I had in mind, since you take care of the whole alignment (scale and rotate) at once.
If it would be possible to add this to Moi, it would be a huge help when working with references.
1982.11 In reply to 1982.10
Hi okapi, I'm glad that will work for you - yes I should be able to add this in for the next beta which should be ready pretty soon. That was actually a screen capture of it working inside of MoI right there.
It will be a new button that will show up here:
When you have multiple images, the one that will be edited is the one that is highlighted in the list, so that part is a little different than dragging images.
1982.12
This is excellent.
Many times in blueprints you have exact dimensions for wheel base, total length, etc.
What a time saver!
This alignement will also valuable with the normal Edit frame box?
1982.14 In reply to 1982.13
Hi Pilou - no not currently, as you can see in this post here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1982.11
it is actually a special part of the Image command that you activate by pushing the new "Align" button in the Image options panel.
It isn't activated by doing anything on the edit frame, it is a totally separate thing from that.
I do want to add an additional kind of align/orient tool for objects as well though, but again it will likely be a new transform command and a separate thing from the edit frame.
1982.15 In reply to 1982.14
thx for the precisions :)
Show messages: All  1-8  9-15
