move scale roate f BAckground images
All  1-6  7-15
1982.7
Hi Michael, this is how I position Background images at the moment.
The problem however is that quite often the background image I have (let's say a Cad plan printed as a PDF, then saved as an image)
does not have a precise length and width.
The precise information I have is the drawing itself. So in your exemple, with the car, it would make more sense for me when placing the image if:
- I drew a line that is 4 meters long (or however long the bottom edge of the chassis is)
-Moved the image by clicking on the image on one point of the equivalent line at the bottom of the chassis, then draging and snapping the the equivalent point on the line.
-Then scale the image by clicking on the same point again, clicking on the other extremity of the bottom edge of the chassis (on the image) and scaling down, by selecting again the other equivalent point of the line.
Just like I would If I had a reference nurbs object, and I wanted to scale down another object to fit exactly to it.
Basically, sometimes it does not makes as much sense to use the edges of the drawing as reference to place an image, it would be better if I could click somewhere on the image.
Maybe it is not clear, if I find a small break today I can generate a gif showing what I mean.
1982.8 In reply to 1982.7
Hi okapi - ok thanks for explaining it more, I understand now what you mean.
You should be able to do the first stage, the positioning part, currently - you don't have to drag on a corner of the image, you can drag anywhere inside of an image to move it around to adjust its position.
It's the second part of matching the "registration marks" between the image and the model which is a problem.
It will be difficult to make the regular scale tool work on images, since an image is just not set up to be treated like a regular object. It just does not fit within the regular object and selection mechanism which is what the normal scale command is designed to work with.
But maybe what I can do is add a "Scale" button into the View / Image command to handle this particular image task - there is a pretty good spot for a button under the "Add" button in there right now where it could go.
Do you need to align a rotation in a similar way? Maybe instead of a "Scale" tool it should be an "Align" tool which does scaling and rotation both by picking 3 points.
1982.9 In reply to 1982.7
Hi okapi, how about something like this:
That will let you pick 4 points to do image registration - you pick a base point and reference point on the image (you'll probably want to zoom in there, I didn't do that to keep this screen capture small), then pick a target base point and target reference point snapped on to your geometry.
It will then do a combination of move, rotate, and scale to make the image aligned and sized to the right amount to align with that geometry.
1982.10 In reply to 1982.9
this is great!
This is even better than what I had in mind, since you take care of the whole alignment (scale and rotate) at once.
If it would be possible to add this to Moi, it would be a huge help when working with references.
1982.11 In reply to 1982.10
Hi okapi, I'm glad that will work for you - yes I should be able to add this in for the next beta which should be ready pretty soon. That was actually a screen capture of it working inside of MoI right there.
It will be a new button that will show up here:
When you have multiple images, the one that will be edited is the one that is highlighted in the list, so that part is a little different than dragging images.
1982.12
This is excellent.
Many times in blueprints you have exact dimensions for wheel base, total length, etc.
What a time saver!
This alignement will also valuable with the normal Edit frame box?
1982.14 In reply to 1982.13
Hi Pilou - no not currently, as you can see in this post here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1982.11
it is actually a special part of the Image command that you activate by pushing the new "Align" button in the Image options panel.
It isn't activated by doing anything on the edit frame, it is a totally separate thing from that.
I do want to add an additional kind of align/orient tool for objects as well though, but again it will likely be a new transform command and a separate thing from the edit frame.
1982.15 In reply to 1982.14
thx for the precisions :)
Show messages: All  1-6  7-15
