Script a walk function ?
1975.1
Hi all,
Is it possible to write a script to navigate inside objets (walk fct) and change the fov (wihtout using the zoom) ?
Something like :
script:moi.ui.mainWindow.viewpanel.getViewport('3D').move( 'forward', 8.0 );
script:moi.ui.mainWindow.viewpanel.getViewport('3D').move( 'left', 8.0 );
Thx
1975.2 In reply to 1975.1
Hi Peex - for the first one use the pan() method, like:
moi.ui.mainWindow.viewpanel.getViewport('3D').pan(0,0,8);
It takes 3 values, the first one for a right-left distance, the second one for an up-down distance, and the third one for a forwards-backwards distance.
Use a negative value to go in the opposite direction.
There currently is not any way to adjust the fov, I've been meaning to add that, I'll see if I can add that in.
