Isometrc, Trimetric, Dimetric ?
 1-6  7-26  27-46  47-58
1917.47 In reply to 1917.44
Hi Michael....
> Hi Anis, so you mean you would like to remove the regular Perspective view?
Yup
another idea :
when click the "3D" button twice it will activate "isometric". I think isometric view is one of the most view that need by user.
this will work similar to "top", "front", "right"
-anis
1917.48 In reply to 1917.47
Hi Anis,
So far it does not seem to be needed by very many MoI users because I have had only very few requests for it...
I'm certainly happy to add things that are only going to be used by a small number of people, but it is pretty typical that such things take the form of a script macro or custom keyboard shortcut, rather than it becoming a part of the main default user interface.
That way the main user interface can stay much more simple and approachable to a wider range of people, but you still can get the function that you particularly need by pressing a single key.
It is actually possible for you to modify the UI to have additional buttons if you want, the UI is defined by .htm files that are in the \ui subfolder underneath MoI's main installation folder. If you would like to customize your own particular installation's UI you could do that by editing those files.
On the other hand, if more and more people start to ask about it, then it becomes more likely to get added to part of the default UI.
1917.49 In reply to 1917.43
Hi Michael...
Are you still remember this thread ?
Its has been a while...
Can you please add the scripts for isometric, dimetric, etc to http://kyticka.webzdarma.cz/3d/moi/ ?
How about Danny suggestion to add "ISO" button combine with "3D" ?
So first time 3D then if I click once more will be ISO.
Thanks !
1917.50 In reply to 1917.49
Hi Anis,
That's actually Petr's web site, so you would need to ask him to update it.
> combine with "3D" ?
I don't know - it just seems to only come up so rarely...
1917.51 In reply to 1917.50
Hi Michael...
For MoI user who use MoI for Mechanical parts, I think isometric view is important always use it when I want to create screen capture for example.
Lets see how another user say about this...
1917.52
While I'm a new user to MoI, I've been polygon modelling for 10 years or so, I don't recall ever using Isometric view mode in the various 3D programs that I have used. From what I read in the earlier posts in this thread it is possible to set up a script for this.
What would much more useful is the ability to change the viewport windows so rather than having either 1 or the 4 view split view I could have 2 windows like 3D and Top view when I needed just 2 views. Maybe that's possible by editing the UI. I haven't got that far yet.
Nigel
Homepages: 3dkiwi.co.nz & C4D Cafe
< That's actually Petr's web site, so you would need to ask him to update it.
I will made that (update) in my site, but that will be in French ;) (final tabs ' names of script are in english ;
(that is the Ptr site for the V2 + my own add ; http://moiscript.weebly.com/
for the V1 you have that (exact mirror of the Ptr site for the V1 but in French ;)
http://site.voila.fr/plugmoi/index.htm
1917.54 In reply to 1917.53
In French ?
No problem..., because the script not in France :)
Thanks Pilou....
What is your opinion about make 3D and ISO ?
1917.55 In reply to 1917.54
Done
tab / "Script en ligne" (line script)/Vue(View)/Isometric,Dimetric, Perspective etc...
Copy Past the code and change the French /* notation*/ if you want ;)
< What is your opinion about make 3D and ISO ?
As parameters can be made without difficulty, there is no reason to not permit that ;)
For industry and schemas that can be useful ;)
Problem of complexify UI is another question :)
EDITED: 6 Jun 2010 by PILOU
1917.56 In reply to 1917.54
Hi Anis, well isometric and dimetric views are just parallel views at one specific view angle.
Is there something special about those particular view angles that helps you to do modeling or something like that?
If there was the kind of "switch to isometric" mechanism in the UI like you are talking about, would you expect for view rotation to be then disabled while that special mode was active?
I'm just not very clear on what you see as being the benefit for having that, maybe you could explain some about what kind of problem it would help you solve.
You can already just set your view to be parallel if you want, that is available under under Options > View > 3D view projection. But as far as I know, most people want to be able to rotate the 3D view around to look at your stuff from different angles and not just be locked into a single specific view direction.
1917.57 In reply to 1917.51
Like Anis said, it could be helpful for screen grabs for mechanical parts.
1917.58 In reply to 1917.57
Hi Kevin, if its only purpose is just for screen grabs and not for actually doing any modeling work, then it may not be a great fit to try and jam it in with other things that are used frequently for modeling...
It could be something that fits better with some kind of UI customization in the future where you could go to a script library and pull in some buttons for functions that suited your particular needs.
Currently that kind of stuff is dealt with by keyboard shortcuts, right now if you do want to set up an isometric view for doing a screen grab, that is possible by setting up one of the keyboard shortcuts listed earlier in this thread.
Show messages:  1-6  7-26  27-46  47-58
