Import Second Life Sculpties into Moi
All  1-10  11-20
1897.11 In reply to 1897.10
Hi jonah, it's similar, except instead of defining a vector displacement from an existing point the sculpt map defines the base 3d point location itself.
It's not a texture that is applied to existing geometry, it actually defines a piece of geometry by itself.
1897.12 In reply to 1897.11
Post a sculpty map you want in MoI.
1897.13 In reply to 1897.11
i see. so there really is no "mesh" object at all in the space? that's a pretty cool idea.
1897.14 In reply to 1897.12
To BurrMan
Here's a couple basic sculpties for ya.
1897.15 In reply to 1897.1
Hi Rose, I've made a converter program which you can get from here:
http://moi3d.com/download/Sculpt23DM.zip
Unzip it to get the Sculpt23DM.exe program and a couple of DLL files that should go alongside it in the same folder.
Then you can run the program, it will prompt you for an input .tga file and an output .3dm file and then it will do the conversion and create the .3dm file at the end.
There doesn’t seem to be any built-in way to determine if a sculpt map is supposed to be closed in one direction, for this conversion I just take a look and see if the points are sort of close together along one edge and if they are then I close that direction. It is possible that some sculpt maps may not end up being closed with this method.
But I hope this will help to be able to get some of your data into MoI.
1897.16 In reply to 1897.13
Hi jonah,
Each pixel in the sculpt map will become one vertex of a mesh object that is created from it.
It would actually be a lot easier if Second Life supported regular polygon mesh data instead of this kind of custom type of object, they seemed to develop this method since it would kind of fit within their existing image streaming type data flow or something like that...
The other thing for their purposes is you can easily do some stuff like sample a few points in it to make a rougher version.
1897.17 In reply to 1897.16
Hi All....
Any body can tell me what is sculpt map ?
How we can create it ?
When I open the Heel 1 I just see image below :
After convert using sculpt23dm :
So, the source file compare to the result is very different.
EDITED: 19 Jun 2010 by ANIS
1897.18 In reply to 1897.15
Oh my, that is just amazing! thanks so so so much Michael!
1897.19 In reply to 1897.17
Hi Anis,
It's a particular kind of file format used by the Second Life simulator/game software.
One way to create one is to create a surface in MoI and then use the 3dm2sculpt converter program available here: http://wiki.secondlife.com/wiki/3dm2sculpt .
There is some more general information on them available here:
http://wiki.secondlife.com/wiki/Sculpted_Prims:_FAQ
They are only of use if you are using the "Second Life" program though, they are not used by anything else.
1897.20 In reply to 1897.16
Thanks for your explanation. I imagine they could also resize the image "on the fly", and therefore reduce mesh density based on distance from camera. it's a very interesting concept...
jonah
"The other thing for their purposes is you can easily do some stuff like sample a few points in it to make a rougher version.
- Michael"
Show messages: All  1-10  11-20
