hello kitty gives me headaches
All  1  2-4
1891.2 In reply to 1891.1
> Does anybody has an idea how to get this smooth transition
> between the legs and the belly while keeping the "hard edge"
> between the legs?
I think what you want there is to apply a fillet for the upper belly part, but no fillet between the 2 legs.
Something like this:
Started by drawing a profile curve:
Then select it and run Construct / Revolve to build one leg piece:
Select that leg and run Transform/Mirror to duplicate it on the other side, then select both legs and run Construct / Boolean / Union to fuse them together.
Then I drew another similar but larger profile above:
Revolve that one, Mirror it, then make another larger version in the middle:
Now boolean union those upper 3 pieces together - this will create edges where the pieces intersect each other, you can see the black edges appear here:
Now select that piece and run Construct / Fillet to round off those edges:
So I think the thing you're looking for is just a boolean union with no filleting for the lower leg portion, but then boolean union plus filleting for the upper part.
Hope this helps!
1891.3 In reply to 1891.2
Hi MichaelW...
Looking forward the final MoI Model.
1891.4
Thanks for your fast reply.
I will try this out and hope to show you some results soon.
Michael
Show messages: All  1  2-4
