A couple simple suggestions for V2
All  1-6  7-14
1887.7 In reply to 1887.4
Hi Len,
> Yes, I do mean the ones at the bottom of the viewport. For me,
> they get in the way and I had delete the image file so they don't
> load up. It would just be nice to be able to turn them on and
> off, that's all.
For the next beta I've added a checkbox option to control this under Options / View / Show view controls.
So with the next beta you'll be able to go there to turn them on and off, and that setting will be saved to the moi.ini settings file.
1887.8 In reply to 1887.5
Hi okapi,
> It would be nice if we could eventually assign icon shortcuts to
> scripts, and place these in the layouts.
I do want to add a kind of "plug-in" menu so that you can have a list of scripts that show up in a menu instead of only on a shortcut key. But I just haven't had time to focus on that yet.
In the meantime, that plug-in gallery dialog that Burr is mentioning may be a good option for you, Petr's page that has the links discussing that are here:
http://kyticka.webzdarma.cz/3d/moi/#PluginGallery
It's also possible to edit the UI definition files which are text files in the \ui subfolder inside of MoI's main installation folder.
For example to add an "Isolate" button to the bottom toolbar, you would do the following:
Open up the CommandBar.htm file in notepad, you can find it inside the \ui subfolder inside of MoI's main installation folder.
All the various controls on the bottom toolbar are defined down here, and you can insert a new one by adding some text in here.
Just before the ending </body> tag near the bottom of the file, add this:
<moi:CommandButton onbuttonclick="moi.geometryDatabase.invertSelection(); moi.geometryDatabase.hide(true);">Isolate</moi:CommandButton>
So it should look something like this near the end of the file:
			..... more stuff up here .....
			</moi:StateButton>
		</nobr>
	</body>
</html>
Now when you run MoI the next time, there will be an "Isolate" button on the bottom command bar, next to the Object Snap toggle button.
You can add in other buttons in a similar way.
The main problem with this is that every time you get a new beta release, you will need to repeat this procedure, so you may want to keep a link back to this message so that you can refer back to it.
I do want to make this easier in the future, this is just a way that you can make it happen with your current version if you want.
1887.9 In reply to 1887.7
That's fantastic Michael, you're the best!
Just a couple other suggestions. It would be nice to be able to lock the zoom level of all 4 windows together when working in a quad view. Sometimes I find it's hard to work with an object that is a different scale in every window.
Also, is it possible to put a switch in to orient the work area so Z is depth and Y is up? That's how all the programs I use are set up and it would be nice to be able to be consistent.
Cheers!!!
Len
1887.10 In reply to 1887.9
Hi Len,
For the next beta I've added a new "Link ortho views" option which will show up under Options / View / Rotate/Pan/Zoom options:
When this option is enabled, when you do any zooming or panning in one ortho view the remaining ones will automatically update to center in on the same spot and same zoom level.
By default this will not synchronize the 3D view though - the 3D view by default uses a perspective type display which handles zooming and the field of view in a very different manner than the Top/Front/Right views, and it just is not really possible to make its zoom scale exactly equal to the others because of the perspective foreshortening where objects that are far away will be smaller in the perspective view.
But if you turn off perspective for the 3D view (which is another new option for the next beta under Options / View) then that view will also synchronize with the others.
I'll take a look... I'm not so sure about this one though it may require tinkering in too many places. But it may be possible to do a kind of superficial "display label" type change.
1887.11
A magician as always Michael, we ask, you create!
Well, let's hope that all our crazy wishes won't make MoI too complicated... I mean not only the UI but the application itself.
***Modeling Of Ideas***
1887.12
Thanks a million Michael! That just great!
I'm looking forward to starting another major project with MoI soon.
Cheers!!
1887.13 In reply to 1887.12
Hi Len, I was able to get in some options for changing what directions are labeled as x, y, and z for the next v2 beta.
The way it will work is first there is a new button on Options / View:
If you push that new "Axis labels" button this new dialog will pop up:
That dialog will let you set the labels to use for the right, forward, and up directions - to try and clarify them they are labeled here as "Top view horizontal" for right, "Top view vertical" for forward, and "Elevation" for up.
The default is the same as before, with the Top view using x and y making a kind of "blueprint plan" with z being the elevation up from the "tabletop plan", that is pretty much the standard for CAD programs.
To use the kind of animation-style x/y in the front view, you will want to change this to be like so:
Then I think it will behave like you are more accustomed to, here is a shot of how the axis icons look when changing that setting:
When you change this option, it doesn't really change how data is stored internally or written out to any files, it changes a few specific areas though to give you sort of feedback and UI using your label preference. The optional axis icon in the lower left corner will show up using your label choice, the label on the base point of straight snap will display using your labels, axis snap will show "On x", "On y", etc... using your labels and also the x,y,z point readout and x,y,z typed-in point input will use your labels as well.
There are a number of things that will not change though, like technically that coordinate system above there with x/y on the front view is a "Left handed" coordinate system which is supposed to handle rotation directions slightly differently - that will not be different but that detail is probably not likely to affect you very much, it just means that the rotation that you get by using something like the Rotate axis tool will not be technically correct for your custom coordinate system, the "positive" angular direction will still be determined by the right-hand rule instead of a left-hand rule.
But I think that having all the x,y,z coordinate feedback using your labels should do the trick well enough and I doubt that you will notice the parts that are technically incorrect for rotations and angle measurements.
1887.14
That'll do the trick just fine! Thanks so much!!
Show messages: All  1-6  7-14
