Hi okapi,
I have set up drag & drop support for the next v2 beta.
After you drop a File or Files on the MoI window, There will be an options dialog displayed:
If you use "Open file" the current file will be closed and replaced by the new content.
If you use "Merge file", then any current data will stay in place and the dropped files will be added to it the same as the File/Import command.
If you have an empty scene then it will not prompt you and will do an Open.
If you want to open everything in separate MoI program instances, then do a right-click on the files in Windows Explorer and pick "Open" or "Open with", that should open them in that way.
