Freeform drawing
All  1-3  4-5
1885.4 In reply to 1885.3
As a follow up Michael, I was just fooling around and found I could go through quickly and "Generally" place points close, then turn on show points and go back and get pretty good results by moving things until an exact match showed. Feels like the way it should be.
Burr
1885.5 In reply to 1885.4
Hi Burr, yes I think that last description you put in (go back later and adjust with show points to refine) is a good idea.
After a bit of practice you can start to get used to the way the control points work, you kind of place them slightly to the outside of where you want the curve to go, since the curve is kind of shrunken and smoothed down from that control point hull.
After you practice it for a bit, it gets easier to trace things.
Show messages: All  1-3  4-5
