Where to go from here!
All  1-13  14-16
1870.14 In reply to 1870.13
Hi Burr,
> BTW: Can Parametric be NURBS?
Yes - the standard type of parametric software generates NURBS objects. The objects themselves are NURBS using the same type of geometry that MoI use.
The stuff that makes it "parametric" is the workflow, the UI, and all the other history mechanisms and editing tools which are all extra things than just the NURBS surface geometry.
> What is solidworks?
It's a parametric history-based solid modeler.
1870.15 In reply to 1870.14
Hi Burr & All....
Basically I come from solidworks. I have been use solidworks for 3 years. Its a powerful solid & surface modeling also. The big different is solidworks have a parametric concept like Michael mentioned before. As I know solidworks is the easiest parametric modeling software.
But today my favourite software is MoI ( because the easy to use workflow & of course MoI is very affordable ).
You can open MoI file directly use solidworks. So it will give you a good combination.
You can find some solidworks video here : http://www.solidworks.com/pages/products/swofficepro/SWOfficePremium_VidVau_fore.html
Also check this link : http://download.rhino3d.com/download.asp?id=rhino-solidworks
OK, that is my opinion ;)
EDITED: 15 Aug 2008 by ANIS
1870.16 In reply to 1870.15
Thanks guy's. I think I would utilize both. The training I will start with Rhino for a bas then move to solidworks to add to the toolset.
Thanks again.
Burr
Show messages: All  1-13  14-16
