Wish for V2
 1-16  17-35
1869.17 In reply to 1869.13
Hi Petr, I guess I could add angle in there... I was kind of thinking of leaving that out since I also at some point want to have some dimensions too, which are then kind of starting to replicate many of these things.
Like is it really necessary to have both an Angle dimension as well as a 4 point angle command?
1869.18 In reply to 1869.14
Also just as note from me so you dont have to do such an involved test to see if you've acheived solid. This script with a shortcut tells if it's solid.
"script:moi.geometryDatabase.getObjects().getSolids().setProperty( 'selected', true );"
Ignore if not pertinent.
Burr
1869.19 In reply to 1869.13
Hi Petr - re: center of gravity point - I think this will probably be included within the area/volume commands.
1869.20 In reply to 1869.18
Hi Burr, yes that is actually a good tip - that is the way you can currently tell if an object is a completely closed solid or not.
But I do want to make that information more easily accessible so that you can tell just by selecting an object and looking a display panel.
The other thing is that once you determine that an object is not a solid, you don't really have any way of seeing which edges on it are responsible for it not being closed off - that's the other part that Danny is talking about.
1869.21 In reply to 1869.17
From my point of view, the Point, Distance, Angle analysis tools are unnecessary. I can replace it by using different regular commands and construction line together and reading feedback in the input boxes on toolbar at the bottom.
It might be better to have a basic dimensioning capabilities as soon as possible to make such data like point coordinates, distance or angle more persistent/permanent....(?)
Petr
1869.22 In reply to 1869.17
Hi Michael
Your last point there is a good one. I would say that one could use dimension tools to permanently measure things, or just to check things as you go.
angles, length, area, volume etc:
Could there be a kind of situation detection; like clicking on a line will give a horizontal dimension if the line is horzontal, clicking two angled lines would automaticly make a angle dimension, etc?
A solution to the "redundancy problem" is also to have a "make permanent" checkbox, so if you just want to check things as you model but don't want dimension objects you can just leave it unchecked...?
Do you have plans for some type of draft angle analysis tool?
-Fredrik
1869.23
Thanks Michael,
To the tune of Homer Simpson, mmmmm....naked edges....uhrrrr :D
Thanks for the tip Burr !
1869.24 In reply to 1869.23
Michael,
The properties is something I'm really looking forward to. Seems one of the first things I look for that blows me out of the water when I open rhino and other such packages is, if I make a 5 inch sphere here, then want to adjust it to there in relation to this that and the other, I cant see how outright. The properties panel will handle this for the "Visual" type people.
Here's a grab from an art package called Carrara that has the kind of properties I mention in particular.
At any point i can select an object and SEE where it is and how it relates to others. To move it i just select the x value, type a new one and it moves there.
I know the same thing can be acheived in MoI now, though the point is this is a way many people think and this feature, even if it is a selective feature so some can disable it, would be most desirable in MoI!
Thanks for the effort.
Burr
1869.25
Hello everyone,
Just a little input from a non technical user, would it be possible for example, to automatically show this naked edges when a boolean operation failed.
Just to have some user friendly feedback.
This kind of smart tools would be welcome for artists (like me) that don't have a clue about tolerance and all this math nurbs stuffs :)
Generally I think there are many tools that sometimes don't work, not because of MoI, but because of the user. For example asking a to large fillet size ... instead of just failed, having some feedback would be helpfull, like showing edges or area where the fillet exactly fail.
1869.26 In reply to 1869.17
Also I guess it wouldn't be a huge problem for users let you discard some commands as time goes by...(for example I remember asking you to merge Revolve / Rail revolve commands into one :)
Petr
1869.27 In reply to 1869.23
Hi Danny, I have added some scripting stuff for the next beta now so that it will be possible to make naked edges (edges that are not attached to another edge) selected so that can help to show you what parts of an object are the ones stopping it from being a closed solid.
The script for this will be:
script:var gd = moi.geometryDatabase; gd.deselectAll(); var breps = gd.getObjects().getBreps(); for ( var i = 0; i < breps.length; ++i ) breps.item(i).getNakedEdges().setProperty( 'selected', true );
Again - that won't work in the current beta but will in the next v2 beta.
EDITED: 16 Aug 2008 by MICHAEL GIBSON
1869.28 In reply to 1869.27
Thanks Michael, that script will be a great time saver, where you don't have to stop the work flow to get the model analysed.
So quick ! too.
1869.29 In reply to 1869.8
Hi Michael..
Below is solidworks mass properties calculation :
1869.30 In reply to 1869.29
Thanks Anis! I don't really expect to have anything close to that amount of complexity in MoI's mass properties calculations, I think in MoI it will just display a volume and possibly a center of gravity.
If you need an extensively detailed mass properties report, then probably exporting to something like SolidWorks will be the way to go.
1869.31 In reply to 1869.30
Hi Michael...
How about :
In the object organization, we can add density manually for each layer / object.
Then MoI will calculate volume multiply by the density value that we have added before.
If we not enter density value, then MoI will only calculate volume.
Not fully automatic, but it will very helpfull rather than only calculate volume.
Thanks !!!
1869.32 In reply to 1869.31
Hi Anis, that's certainly possible, but one big thing that people have requested for MoI over and over again is to keep the UI light and easy to use....
Adding in many different kinds of parameters tends to clutter up the UI and over time will make it harder to find the primary functions of MoI in the middle of a bunch of stuff.
So this tends to make me hesitate before adding in things that require additional UI.
That's why at first I plan to just have a simple volume calculation, since that will produce the smallest amount of UI. Then later I can look into adding in additional functions once the basic stuff is in place.
1869.33 In reply to 1869.31
Maybe, rather than upset the simplicity and ease of use of MoI, there could be a LOT of the requests for things in MoI being put into a NEW, special ,App/Plugin (or whatever)that would do a lot of these things.
It could include things like Obj23dm,MergeOB,GroupHelp,Separate------ etc?
Like a Shortcuts on (Drugs/Coopers Stout) sort of thing!
Brian
1869.34 In reply to 1869.33
Hi Brian, yup that is actually what I try to do when possible....
That's why there are a variety of custom plugins on Petr's page here: http://kyticka.webzdarma.cz/3d/moi/ - those were added as plugins to provide some useful functions to MoI for specific things, but without having an impact on the regular UI.
Probably a weight calculation could be added in a similar way, like a plugin that does a volume calculation but also has a list of different materials so you can get the weight easily.
But really it is not a very difficult thing to get the weight once you have the volume - it just takes one multiply to get it.
1869.35 In reply to 1869.34
Hi Michael...
In my opinion, Just go a head with your original idea on "object organization", post some preview of the result then we will give you some feedback.
Cheers !
Show messages:  1-16  17-35
