MoI System Requirement All  1  2-9
1857.2 In reply to 1857.1
Hi Anis, MoI has pretty minimal system requirements.
OS : Windows 2000, XP, or Vista.
Graphic card : Direct3D9 video card, 64MB VRAM or higher.
Processor : 1Ghz Pentium or higher
RAM : 512Mb or higher
MoI will actually run on a system with less than those specs, but those are generally what I would recommend for a minimum. It is a good idea to test a system with the trial version to see if it is going to work ok.
If you're going to be doing larger models then a faster processor and a larger amount of RAM are recommended.
1857.3 In reply to 1857.2
Hi Michael...
Thanks for your quick reply.
I think its very important to put Minimum hardware recommendation on the MoI Resource Page or Main Page.
This will very helpful for who want to buy new machine for MoI.
Regards,
Anis
1857.4 In reply to 1857.3
Sorry Michael....
How to check --> Direct3D9 video card, 64MB VRAM or higher
-Anis
1857.5 In reply to 1857.4
you can type dxdiag at the run command, then look at the display tab. It will tell you about your video card and you can run a test to see if you qualify to run direct3d.
Burr
1857.6 In reply to 1857.5
Hi Burr...
OK, I see now.
Thanks ;)
1857.7 In reply to 1857.3
Hi Anis,
Just a quick note - pretty much any new machine should be able to run MoI.
It would have to be a fairly unusual system for a brand new one not to run MoI.
If you have a much older machine then it may need a video card upgrade... Machines that are older than about 5 years old may not have a 3D-capable card in them.
1857.8
Any plans to use DriectX10? As I understand from what I read it can increase performance by up to 20-30% compared to DirectX9.
1857.9 In reply to 1857.8
Hi Val, currently I don't really plan on focusing on DirectX 10 anytime too soon - one big problem with it is that it is Vista only, and the majority of people using MoI are currently on XP.
The performance improvements for DX10 are not really like 20-30% totally across the board, it's more in some pretty specific areas which I already took care to avoid running into with MoI's DX9 usage. So I actually would not expect to see any performance gain by using DX10 in MoI's particular case.
There is a bunch of interesting stuff in DX10 for certain special effects, but there is still a lot of stuff shader stuff available in DX9 that I haven't really dug into too much yet.
I think just the DX9 level shaders will keep me occupied for a fair while when I get a chance to work on more of that stuff.
Show messages: All  1  2-9
