"shortcut" please help
All  1  2-10
1845.2 In reply to 1845.1
Hi tytan,
First you need to open up the Options dialog. There is a button for it in the lower-right area of the screen that you need to click:
After you click that, the Options dialog will open up. There will be some different categories in a column on the left hand side, click the category named "Shortcut keys" to open up the shortcut key manager:
Press the "Add" button to put in a new blank entry, then fill in the left-hand side labeled "Key" with the key that you want to trigger the shortcut, for example if you want it to be triggered when you push the A key on the keyboard, put A in there.
Then paste the script into the "Command" column on the right-hand side.
Hope this helps!
1845.3 In reply to 1845.1
Hi Tytan,
Example:
I saved a script called 'SpurGearProfile.js'
in the commands folder (Moi1.0/commands)
Then options -- Shortcut keys
Click the 'Add' button and then G(facultative)
on the keyboard
Click on the colon named 'Command' and
write SpurGearProfile
Moi3d is now ready to execute button 'G' on your
keyboard
I hope i did understand your question!
1845.4 In reply to 1845.2
hi Michael Gibson.....it thanks for watch glass answer...
I do not know where option is "Shortcut keys"
this my screen
1845.5 In reply to 1845.4
Maybe you have an older version?
1845.6 In reply to 1845.4
Hi tytan, something seems to be wrong with your installation - the options dialog is not supposed to look like that.
You might try uninstalling and re-installing MoI to see if that fixes your installation.
Also, have you installed something like a beta version of IE8 on your machine? That could possibly interfere with MoI's UI display...
1845.7 In reply to 1845.5
nothing this helped.... :-(( .....thanks with all
I have old version surely
1845.8 In reply to 1845.6
I will reinstall.... this will help maybe
1845.9 In reply to 1845.8
Hi tytan, now that I look into it some more, it looks like the problem is that you are using an old version.
Please download the newest version and then it should look like the screenshots that I was showing.
1845.10 In reply to 1845.9
thx Michael Gibson
Show messages: All  1  2-10
