2D-Enlarging odd shapes by the same amount in every directions
1833.1
How can I replicate a 2D ovoid kind of curve slightly larger but with a constant distance between the two curves?
Scale does not seem to work for this.
Gaston
1833.2 In reply to 1833.1
Hi Gaston - for that use Construct / Offset - that generates shapes at a constant distance from an existing one which as you noticed is a different type of thing than scaling.
So for example if you have this curve:
Construct / Offset will create new curves that are a constant distance away, like this:
Those are offsets calculated at a distance of 1, 2, 3, and then 4 units.
1833.3 In reply to 1833.2
Exactly what I want :)
Thanks Michael.
Gaston
