Boolean diff
All  1-3  4
1814.4 In reply to 1814.1
Hi Olga, also you may want to check out this recent message:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1810.2
That has a short tutorial on another way to select objects that are inside of other ones by using the left-to-right window select, which only targets objects that are completely contained inside the selection window.
If things are getting in your way though, definitely hiding is a good way to deal with that problem.
Don't hesitate too much to hide things.
Also kind of a vaguely similar situation is if you are having difficulty targeting a particular point to snap on to, it is a good habit to get into to zoom in to make things easier on yourself rather than struggling with trying to work in an area that you can't clearly see.
Show messages: All  1-3  4
