smooth joint
All  1-2  3-4
1806.3 In reply to 1806.1
A curve line is always smooth by nature ;)
So your object is smooth by essence
As nurbs are tensile surfaces between curves your object is also naturaly smooth:)
Now you can change the form of the "profil" as you want
Or just select your middle line and use function Transform/ fillet with 0.3 by example
So jonction between 2 wings part will be softy :)
ps Michael show you a more elaborated process ;)
EDITED: 22 Jul 2008 by PILOU
Size: 13.1 KB, Downloaded: 9 times, Dimensions: 219x331px
1806.4 In reply to 1806.2
Hi Michael
Thank you very much.
I did line trim and blend - it worked really well
I also tried freeform curve trim and blend and it did too.
I appreciate your assistance.
Olga
Show messages: All  1-2  3-4
