complex surface shelling
All  1-12  13-17
1802.13 In reply to 1802.12
Hi Danny, yeah I think that is correct. I'm just not quite following along so well with some of the later stages being described there, having a model to look at to go along with a description is always helpful to clear things up.
1802.14
Hi Michael hi Danny
I attach the file where I tried to shell the surface of my design for a pendant
I could not shell the whole thing so I blew up the surface and shelled it in parts but could not join them together and remove extras (I tried Boolean union, merge)
I did not shell two small top corners so this has to be fixed also
Please take a look – you might have an idea how to merge them together and remove extras
Here the thickness is 1 mm.
-Olga-
1802.15 In reply to 1802.14
Hi Olga,
It's a bit of work, spent about 20 min on it but it was a combination of offsets, untrims, trims, booleans, separations and a front end labotomy ;)
If you really, really need a step by step explanation (please say no) ;) then I'll need some time.
It's basically what Michael said earlier Here about 'low level' approach.
I was going to give up after 10 min but it got the better of me so I had to finish it.
EDITED: 26 Jan 2010 by DANTAS
1802.16 In reply to 1802.15
Hi Danny
No I do not a step by step explanation
That looks exactly I want to achieve.
Did you use my latest file or the earlier one with only the basic surface with no thickness?
-Thanks - Olga-
1802.17 In reply to 1802.16
Hi Olga,
this one 0473-9.3dm
Show messages: All  1-12  13-17
