actions tree and quote editor
All  1-5  6-8
18.6 In reply to 18.5
At first the history is not going to be quite the same as full parametric modeling, it will be more focused on letting you edit the curves that were used as input to other commands such as extrude or loft.
But I have a lot of plans on improving the history over time, eventually it will become more possible to do more types of parametric style stuff. But the thing that will probably be missing altogheter is the concept of "constraint-based", which is another mechanism that those parametric solid modelers are based on. But that's also the part that makes them feel like you need to be working on a blueprint as well... It is powerful for a lot of things but as you mention tends to force you to do a lot of set up stuff, you don't get to freely draw so much.
You'll be able to mess around with the first history stuff in the next beta, which is looking like it will be on Monday.
18.7 In reply to 18.6
AHHHHH, so that's what "constraint based" means. I always wondered but never bothered to find out. Avoiding that sounds like a good idea. When you get into that you're going against some ridiculously serious competition. haha
18.8 In reply to 18.7
Yeah, it's the stuff where like you can like assign explicit dimensions to stuff like width, height, radius, etc.. and then have other parts of the model adapt or recalculate themselves according to the constraints. Then you might manipulate the constraints to provide for a family of parts and such.
Yup. Plus there are already a lot of things out there that handle this type of a thing quite well, I didn't really want to do something that was just the same as other things already out there, didn't seem to be much point in that.
Show messages: All  1-5  6-8
