video tutorials
1798.1
Are there any new tutorial videos for MoI that anyone has found (or, made) other than the tutorial links on the site?
How well, or not, is anyone's experience exporting a base mesh to ZBrush?
1798.2 In reply to 1798.1
Hi shokan,
Not that I'm aware of...
> to ZBrush?
I've heard that people have gotten good results going to ZBrush using OBJ format, with Output: Quads & Triangles (ZBrush does not handle n-gons well, so you want to switch n-gons off when you export from MoI), and also using the "Divide larger than" setting to dice polygons up into smaller more evenly sized pieces also helps a lot, there is an illustration of that here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1549.4
1798.3 In reply to 1798.2
For anyone interested in posting their own MoI video tutorial, there is a thing called the Jing Project at:
http://www.jingproject.com/
It's free for now and the res is high, OK frame rate, and it's full screen (no audio). I've used it, it's great. Techsmith (Camtasia) is doing a test martket I guess. I haven't heard of a size limit, and Techsmith tells me the free offer will last for some time still.
There is also Slideshare which is really good for making slide show tutorials. I saw one for an open-source box modeling program and I found stuff really sinks in fast with this simple type of Powerpoint type of presentation, maybe better than a video because you control the progress step by step.
http://www.slideshare.net/
1798.4 In reply to 1798.3
Adding to post above. Apparently you CAN have audio with your video. Also, I think it's a 2G limit.
