wanted: Select after creation
All  1-4  5-7
1793.5 In reply to 1793.4
Hi Steve, Hi Nick - if you would always like to have the created objects be the exclusively selected objects (with everything else deselected) instead of being added to the current selection, then use this script instead:
script:moi.geometryDatabase.deselectAll(); var a = moi.command.lastCommandRevisionStart; var b = moi.command.lastCommandRevisionEnd; var objects = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objects.length; ++i ) { var obj = objects.item(i); if ( obj.databaseRevision> a && obj.databaseRevision <= b ) obj.selected = true; }
1793.6
Thanks. :-)
1793.7 In reply to 1793.5
Hi Micheal,
It is not a script I use, but just added it on my setup to check before posting.
I did not want Nick to find out later he may be moving (or whatever) other previously selected objects after running the script. I think automatically de-selecting all before is a safer option (IMHO)
- Steve
Show messages: All  1-4  5-7
