wanted: Select after creation
All  1  2-7
1793.2 In reply to 1793.1
Hi Nick,
Yes there is a script for selecting the last created object(s). Have a look here:- http://kyticka.webzdarma.cz/3d/moi/
Go down the list and you will find:- SelectLastCommandCreated
OR
the script is:-
script:var a = moi.command.lastCommandRevisionStart; var b = moi.command.lastCommandRevisionEnd; var objects = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objects.length; ++i ) { var obj = objects.item(i); if ( obj.databaseRevision> a && obj.databaseRevision <= b ) obj.selected = true; }
1793.3 In reply to 1793.2
D'oh. I totally missed that. Thanks.
-Nick
1793.4 In reply to 1793.3
Hi Nick,
I just noticed with this script that it does not de-select all objects first, (you may have an object selected during the creation of the new object) so, you could actually have more than the last created object(s) selected after the script as run
1793.5 In reply to 1793.4
Hi Steve, Hi Nick - if you would always like to have the created objects be the exclusively selected objects (with everything else deselected) instead of being added to the current selection, then use this script instead:
script:moi.geometryDatabase.deselectAll(); var a = moi.command.lastCommandRevisionStart; var b = moi.command.lastCommandRevisionEnd; var objects = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objects.length; ++i ) { var obj = objects.item(i); if ( obj.databaseRevision> a && obj.databaseRevision <= b ) obj.selected = true; }
1793.6
Thanks. :-)
1793.7 In reply to 1793.5
Hi Micheal,
Thanks.
It is not a script I use, but just added it on my setup to check before posting.
I did not want Nick to find out later he may be moving (or whatever) other previously selected objects after running the script. I think automatically de-selecting all before is a safer option (IMHO)
- Steve
Show messages: All  1  2-7
