Old Door by Steph
All  1-4  5-6
178.5 In reply to 178.4
In some progs when you have some same objects, when you "named" the first and copy it, it's less heavy than x time a same object without "named"!
Is that possible in Moi in the futur?
Useful for example for the little spheres of the Steph lamp post reflector :)
178.6 In reply to 178.5
At some point yes, but not for quite a while though.
But this type of instancing thing would probably help in a different type of "heavy"-ness - these types of duplicated objects would take up less system RAM, but it probably would not help so much with display speed though.
It depends - if those spheres are booleaned to the main structure, then that type of copying probably won't be able to be used, it would most likely be only for totally independent objects.
It is possible that the edge curve drawing is actually slowing down the display on that model more than the meshes... There isn't currently any way to set it to draw rougher edge curves, I may be able to add something in for that.
Show messages: All  1-4  5-6
