moi_report1.zip ?
All  1-5  6-8
1763.6 In reply to 1763.5
Hi rampackwobble, sorry I think I gave you wrong information there - I forgot that on the dialog it shows you where that file is located.
I think you're running into a another thing that Vista does where it kind of "fakes out" programs that want to write data under c:\Program Files - it tells them that it wrote it there but actually writes it to a different location. Kind of confusing.
Please take a look under this location:
c:\Users\[your login name]\AppData\Local\VirtualStore
I think under there you'll have an additional "Program files (x86)" folder, with a MoI folder and then the crash report file inside of there.
I should be able to tune this up for the next beta to ask Vista to not give MoI this "fake" program files folder in this case.
1763.7 In reply to 1763.6
found and sent.
1763.8 In reply to 1763.7
Thanks for sending the bug report!
This was indeed a program bug in Fillet in v2 - there would be a crash if you picked 2 points to define a radius distance, and those points were snapped on to the object being filleted.
I've fixed this up for the next beta, but for the moment when you click those 2 points to define a fillet distance, click them off to the side somewhat and don't click them directly on to the object, that should avoid triggering the bug for the moment.
I've also tuned up the crash reporting so that it won't get tangled up with the kind of "fake" Program files directory stuff that Vista so annoyingly added... So in the future the crash report should actually be in the location that MoI thinks it is in and is reported there on that dialog.
Show messages: All  1-5  6-8
