Need Advice Modeling an Organic Model
 1-7  8-27
1748.8 In reply to 1748.7
I'm interested in this - but have little idea how I would go about it in a nurbs program :(
I hope it goes ahead with people posting along the lines of "I made the ears by altering the point on a solid sphere", "Well I made them by lofting over these lines which I found easier because...".
I don't think we need a "senior member" ( been a user longer, more posts, older ?) to host this - although I hope more experienced users will add there own words of wisdom :)
Anyway here is my first attempt - I am sure it could be improved on .... slightly :).
The ears are the only bit I am no too unhappy with (altered points on a solid sphere :) ) as for the rest....
So come on in - I'm sure with a lot of hard work and effort you could do better than mine :)
Size: 59.3 KB, Downloaded: 35 times, Dimensions: 643x886px
1748.9 In reply to 1748.8
That's not bad!
That's definitely the general approach that I'd use - try to break things down into a few different features like the main head shape, ears, nose, and build those as separate objects and then boolean them together.
I think that one tip would be to try and avoid planar surfaces in general since those won't have a very soft and organic type feel to them. Like the nose there kind of stands out in your version there.
So that generally means using more like Sweep, Revolve/Rail revolve, or Network to build surfaces since those can build a more blobby type rounded shape easier without a planar end.
Here is one overview on how to build a kind of all rounded blobby shape using sweep: http://moi3d.com/forum/index.php?webtag=MOI&msg=415.2
1748.10 In reply to 1748.9
Thanks for the link - I did not know you could "cut" the line like that (up to now I've always added a line first) or used sweep like that - right, that's it, no more playing 'till I've read the manual (or at least had a quick look) :)
1748.11 In reply to 1748.1
Hi Anis
I just had a go at your Giraffe and made it almost exclusively with the network command. I mucked up some bits though working too fast.
Micheal I noticed that when I imported it into Carrara and 3d- Coat that some of the polygons appear darker than others and in 3d-Coat they wont accept textures. Is this because the normals are reversed?
Keith
Size: 18.9 KB, Downloaded: 33 times, Dimensions: 640x480px
Size: 40.3 KB, Downloaded: 49 times, Dimensions: 467x544px
1748.12 In reply to 1748.11
Hi Keith,
Could be... One thing to try is to make sure you have used Edit/Join to glue together individual surfaces at their common edges before exporting.
If you just have a bunch of totally separate surface objects all built by using Network for example, MoI does not know that they are supposed to be connected together with each other, so there is a possibility of each one getting exported with a different normal direction.
If you join them together, that will make MoI process them in a batch and keep all the orientations for the entire joined set consistent. It also helps ensure that the meshing is created in a consistent way along shared edges so that there are matching vertices there.
1748.13 In reply to 1748.12
Thanks Michael
Your very patient, I think you have told me to join things properly before.
Keith
1748.14 In reply to 1748.13
Hi Keith, well it's an extra step and such things are always pretty easy to forget about, especially when it does not immediately look like anything is wrong.
I should probably just do it for you automatically... That's something that I will take a look at doing in the future.
1748.15 In reply to 1748.13
By the way your giraffe turned out pretty good!
1748.16 In reply to 1748.3
Hi Anis,
I used a combination of MoI's tools to make the dog model.
The paws are simple spheres which were *scaled to an approximate oval shape, then control point edited, using the Scaling tools and the Align and Move tools on pairs or groups of points. The head, nose, ears and tongue were also made by control point editing of spheres. A Network Surface was used to make the main body. A 2-rail Sweep would also have worked, but to be able to shape the contours of the body from all sides - front, back, left and right, a network surface seemed to offer more control. Sweeps were used for the limbs and tail. After all the components were constructed, I did a lot of scaling and nudging to position and proportion everything together. The parts were then Booleaned and fillets were applied to soften the seams.
I actually had to go back a few steps in my incrementally saved model and make some revisions after I discovered
the legs were too close together to work as a jewelry model. Here's the final version. As it happened, on this version,
I couldn't get the amount of filleting I wanted on the legs on one side, so I split the model down the middle, deleted
the troublesome side, then mirrored the successfully-filleted side over.
I'll try to do a basic version of your giraffe example later this week with some more details.
Jesse
Edit: Hi Michael, I just tried the frame-edit tool in the new MoI v2 Beta..it definitely makes control point editing easier!
Can it be used to move points as well as scale and rotate?
*Could you also explain how scaling the solid object rebuilds the amount of control points? It makes a big difference in terms of the potential of the object to remain smooth and workable, if that makes any sense. -JDK
EDITED: 15 Jul 2008 by JESSE
Size: 253.9 KB, Downloaded: 83 times, Dimensions: 1003x769px
Size: 250.3 KB, Downloaded: 92 times, Dimensions: 867x773px
1748.17 In reply to 1748.16
Jesse,
Have you tried Petr's "Nudge" tool. It works great for this.
MoI resources-Petr's page. Dobre Je!
Burr
1748.18 In reply to 1748.17
Hi Burr,
Thanks, I do use Petr's keyboard nudge tool, it's very good.
- Jesse
1748.19 In reply to 1748.3
Hi Anis,
For simplicity's sake, the detail isn't quite exact and I made the model symmetrical, even though the pictures show that it varies in shape from side to side. I set up the three images in the corresponding viewports to trace with curves. For the main section, I used a network surface. I modeled most of the other parts from spheres, editing groups of control points. If you turn on the control points on the jaw and ear parts you can get an idea of how the points are "sculpted". MoI's selection tools and display features make it possible to grab points and move them around. I used the align tool, the scaling and move tools and the new frame editing tool in the MoI v2 beta. If you have any specific questions, just ask... :-)
-Jesse
EDITED: 17 Jul 2008 by JESSE
1748.20 In reply to 1748.17
Those scripts on my webpage are mainly Michael's custom command / scripts. Mostly I cite author's name in parenthesis.
>>Dobre Je!
hehe... have you started learning Czech, Burr?
Petr
EDITED: 1 Aug 2008 by TYGLIK
1748.21 In reply to 1748.16
You seem to have had no chance to react to this edited part of Jesse's message...
Petr
1748.22 In reply to 1748.21
Oops, I didn't see that edited-in later part.
To move points, you just drag directly on the points same as v1... Are you asking about a certain kind of movement different than that?
Scaling a solid actually should not change the number of control points in the surfaces in the solid...
Maybe I'm not quite following what you are referring to here though, could you go into some more detail?
(PS - I'll be out for a couple of days)
1748.23 In reply to 1748.20
Sorry no! When I was in Italy I met a Czech girl and all I can remember is jak se maj, ja se mum dobre je. or something like that.
I always wanted to learn czech or russian though never invested the time I needed. Just one of those dreams I have. And always running into Czech guy's playing hockey!
THat czech girl was the most beautiful woman ever!
Burr
1748.24 In reply to 1748.22
Well, I'm a little confused about this...but it looks like when a solid sphere is drawn in MoI and scaled 2d in a particular way, it changes from a 3 degree object to a 2 degree object, decreasing the number of control points...however, when I saved the sphere and opened it in Rhino, it read as a 2 degree object.
My original point was that if you want to control point edit a sphere into another shape, scaling it 2d also reduces the number of control points, making it less shape-able.
Jesse
Size: 71.3 KB, Downloaded: 14 times, Dimensions: 706x1138px
1748.25 In reply to 1748.24
Hi Jesse - I see what you mean.
The part that is confusing here is the "automatic deformable points" feature.
This is what makes a degree 2 sphere that is made up of 4 quadrants instead show the control points of a deformable degree 3 surface approximation. The sphere is actually degree 2 the whole time but if you move one of the points, it will get automatically converted into a rebuilt degree 3 surface approximation so that it can be squished smoothly (you have probably already seen the kind of quadrant segmentation that happens if you move the points on a degree 2 surface that has fully multiple knots in it).
This automatic refitting is only active for surfaces of revolution. If you scale a sphere in the direction that its seam is running, it will remain a surface of revolution, but if you scale it along one of the other directions it will no longer be a surface of revolution and won't have the automatic refitting applied to it.
I think it may be possible to me to extend this to work better in the future instead of only working on surfaces of revolution.
1748.26 In reply to 1748.24
The basic idea is that if you draw a sphere, I want to keep it as degree 2 if you don't need to mess with its control points since the degree 2 version is a totally precise exact sphere.
But if you want to turn on control points and squish it, you get the points for a rebuilt degree 3 version, but the sphere itself does not get changed to use that degree 3 rebuilt surface until you actually drag one of those points around.
1748.27 In reply to 1748.25
Hehe... the "automatic refit with deformable object" feature seems to have a lot of hidden secrets -Petr
Show messages:  1-7  8-27
