2 rail fail
All  1-7  8-12
1747.8 In reply to 1747.7
Thanks Michael, That is great stuff. I'll mow over his scripts more later.
The Shortcut keys are stored in the ini file. My V2 has an ini file in the root directory and it stored them there. (this could be my doing) Is the ini compatible for me to just copy it to the V1 root, (or the app data folder)?
I was moving them around to facilitate the usb install.
Burr (Just call me NURBS)
1747.9 In reply to 1747.8
Hi Burr, yes by default the moi.ini file will go to a central location (in XP it is: C:\Documents and Settings\Michael\Application Data\Moi\moi.ini ).
But when MoI starts it will look for any moi.ini that you may have copied into the same folder as MoI.exe and if it finds one there it will use it instead of the shared one. (this is what you would normally set up to run off of a USB drive).
So if you want to have a particular installation use different settings than another one, that is one way to do it. You can also pass the path to an .ini file to MoI.exe as a command line parameter to make it use a specific one.
The v2 and v1 .ini files are compatible, you can copy them back and forth to one another. The v2 one will write some additional stuff to it, but that's ok those extra new things will just be ignored by v1.
1747.10 In reply to 1747.9
Happy 4th. :)
1747.11 In reply to 1747.10
The rails were a helix on the side, a flat helix on top and projected onto revolved surface. The revolved surface was a cylinder with a domed top, and a fillet around the edge.
1747.12 In reply to 1747.11
Thanks Nick,
Thats a way to get odd yet precise curves. Thanks. I also tried just drawing it. I could, yet wasnt sure how to be precise or if my thinking was the best way. Both yours and Michaels way were great help to me in my learning!
Burr
Show messages: All  1-7  8-12
