Hi Anis,
>>About nudge, I tried those script.
Did you download the file Nudge.zip or NudgeViewAxis.zip?
Could you check a keyboard shortcuts?
If you download and unzip the file Nudge.zip into the \commands subfolder under your MoI main program files folder, the items in the shortcut keys section should look like:
PageUp Nudge zup
PageDown Nudge zdown
You seem to have a script to rotate view there instead(?)
PageUp script:moi.ui.mainWindow.viewpanel.getViewport('3D').rotate( 'up', 6.0 );
>>when I use blend the result will be same if I use fillet
Actually, those shapes are slightly different. The control point structure look similar for both fillet and blend in MoI; but if you would copy the curves to Rhino and turn control points on, you could see the difference.
Like Michael mentioned above:
quote: MoI applies a kind of automatic "deformable" option when you turn on control points for an arc or circle curve.
By the way, why do you exactly need that structure of control points?
Petr
