Hi Petr...
>Did you download the file Nudge.zip or NudgeViewAxis.zip?
I downloaded the Nudge.zip
>Could you check a keyboard shortcuts?
>If you download and unzip the file Nudge.zip into the \commands subfolder under your MoI main program files folder,
>the items in the shortcut keys section should look like:
>PageUp Nudge zup
>PageDown Nudge zdown
Uppsss...not yet set up this.... Now working fine.
>You seem to have a script to rotate view there instead(?)
>PageUp script:moi.ui.mainWindow.viewpanel.getViewport('3D').rotate( 'up', 6.0 );
yes, correct.
>>when I use blend the result will be same if I use fillet
>Actually, those shapes are slightly different. The control point structure look similar for both fillet and blend in MoI;
>but if you would copy the curves to Rhino and turn control points on, you could see the difference.
I see now
>By the way, why do you exactly need that structure of control points?
I just follow a tutorial from Rhino3DTV on how to create a bottle. Check my previous post on this thread. I want to know how we can create the bottle in Moi3D.
Thanks for your tips... :)
