Easies way to create an object in exact location
 1-18  19-38  39-45
1727.19 In reply to 1727.17
Hi Michael, Pilou...
OK, I already understand with existing move command in Moi.
Back to my previous post below :
http://moi3d.com/forum/index.php?webtag=MOI&msg=1727.9
On that post, I create an illustration of the "xpert transform" that I want.
Michael, I think you can combine this feature with Move command. What I mean is like what you have done in "offset" command.
I am aware, I come from parametric modeling software ( SW ).
Below is what I did in SW to place an object in exact location. I know, maybe its rather difficult to put the dimension directly on the model. Thats why I give you idea with the ui of xpert transfrom.
BTW, its a big work to create this "xpert transform" in Moi ?
Thanks Michael.... :-)
1727.20 In reply to 1727.19
Hi Anis,
Well, anything that involves a lot of user interface can be quite a lot of work, I have to be careful about not making MoI become too heavy with so much stuff that it loses the "easy to use" ability of it. That can tend to make me take a slow approach to adding functions that add a lot of interface along with them.
I would also sort of worry a bit in this case about giving MoI the appearance of having constraints when it really does not have them.
But I'll think about it some more, at first I thought it might not really be possible to combine with Move very well because what you are showing there needs to select an "object" which is a different type of pick than a "point location" type of pick. But if I do it in kind of the reverse order from what you show - pick the center of the circle first, then that is more in line with the flow of how Move currently works so maybe that could work. I'm not sure yet though.
1727.21 In reply to 1727.20
Yes, i think the workflow in Moi will be :
- pick object to move, then base line / point for movement
- pick the ref line / point
- then a UI appear to input the distance
I have use SW, but I am very like the workflow and easy of Moi.
So, use Moi as supplement software is a right choice for me.
One of important thing that I want to look in Moi ( In V2 ) is how you can give me / us "a feature" that will help a Moi user to put an object in exact location without any problem and of course easily.
I wish this will be one of your focus in V2 after on drawing on surface & Object properties.
I believe, many Moi users need to put object with accuracy easily.... :-)
Keep Spirit Michael !!!!
Regards,
Anis
1727.22
Right now I'd use a corner to corner rectangle because you can type in the size.
.select corner to corner rectangle
.click start point
.type: 1.2 TAB -1.1 enter
.make circle at corner of rectangle.
.delete rectangle
For the future you could have an expansion of the move tool that adds x,y,z co-ordinates like this:
There could also be an absolute option to move to specific x,y,z co-ordinates rather than relative. I think this is in keeping with the existing interaction and interface but gives precise placement a bit more easily than at the meoment.
Michael, what do you think? Is this possible to do?
1727.23 In reply to 1727.22
Hi Ash,
>.click start point
>.delete rectangle
Never think this before, good tips also.... :-)
Lets wish michael add a "special feature" for this case....
A gain, accurate model is very important.
What is your opinion Moi Users .... ?
Contribute your idea & comment !!!
Regards,
Anis
1727.24 In reply to 1727.23
Could this be done by defining a "Hot spot" for the object and then using a more robust "Properties panel" ?(Size, position, orientation, etc....)
1727.25 In reply to 1727.21
Hi Anis, just to be clear, you do know that you can use existing functions in MoI to place your object in an exact location already, it is not like that is impossible in MoI currently.
To do that, you can use the Move command twice, once to move it to that corner location, and then a second time using the relative point mechanism (or by moving with distance constraint a couple of times).
Please let me know if you are having a problem being able to do this, and I can give you some more individual step-by-step instructions on how to do that with MoI v1.0 .
It would certainly not be bad to have more options for doing this in a way that is more familiar to you, and I'm going to look into that some more. But it is definitely possible to get what you need currently without really any very great difficulty.
1727.26 In reply to 1727.22
Hi ash,
That's actually what this coordinate entry box in the bottom part of the UI is for:
Any time that MoI is asking for a point you can enter x,y,z coordinates there to specify the point location numerically instead of by picking with the mouse.
That works for the Move command, Line command, Circle, Rectangle, Curve, etc..., etc...
Yup, that is actually already the default - if you type in a coordinate without any extra stuff on it, it will be an absolute coordinate.
You have to start the coordinate with an "r" if you want it to be relative, like: r10.1,2.6
There are also other things you can type in there as well, like a polar coordinate where you give an angle and distance instead of x and y - the whole list is in the help file here.
Because so many commands do involve picking points, that point entry UI is in that dedicated spot in the bottom toolbar instead of being in the options area inside each command's UI. In some of my very earliest designs it was in the options area, but it was taking up a huge amount of space and repeated very frequently, that's why it got moved into that dedicated location.
That control does a kind of "double duty" though - it not only allows for entering points but it also shows you the location of the point under your mouse if you are moving the mouse around to pick instead of typing in a coordinate.
Yup, it's definitely a good idea, and it's actually been a part of MoI since the very first 1.0 beta release! :)
1727.27 In reply to 1727.24
Hi Burr,
That's basically what the Transform/Move command actually does - it will ask you for 2 points, and the first point that you pick will be used as that "Hot spot" point.
But I do want to add a properties panel that would be another way to do this just like you are describing, it will probably contain the bounding box dimensions and possibly a center point of the object's bounding box and let you modify those values, and maybe some other things for simple objects like if you have a circle maybe you could alter the radius there.
I want to make that one part of the whole "object organization" set of tools that will be coming for v2, I have not had a chance to get started on this area yet, but it should be happening in not too much longer.
1727.28 In reply to 1727.26
OKay - I admit it. I didn't get this and I totally missed it in the help file :-)
Nice work Michael.
Tony
1727.29 In reply to 1727.28
Thanks Tony - It is a lot more common for programs to kind of have a separate "point readout" (that shows the point under the mouse) and "point input" areas (to type in coordinates).
I did worry about some confusion on that when I made that single "double-duty" control that does readout and input both, that is probably what got you. (because it may be easy to think that it is a readout area only).
But it saves so so very much screen real estate to have things like this that solve more than one problem with the same piece of UI, it's a pretty necessary thing to keep the UI streamlined.
Also one other note - you can click on that control if you want to which will pop up the input panel with buttons on it, but you can also usually just start typing directly and your keystrokes will automatically go there. Like if you want to start a line at the coordinate 2,5 - start the line command and then just type 2,5 <enter> directly without clicking on that box first.
1727.30 In reply to 1727.25
Hi Michaael...
>Hi Anis, just to be clear, you do know that you can use existing functions in MoI to place your object in an exact location already, it is not like that is >impossible in MoI currently.
>To do that, you can use the Move command twice, once to move it to that corner location, and then a second time using the relative point mechanism (or >by moving with distance constraint a couple of times).
>Please let me know if you are having a problem being able to do this, and I can give you some more individual step-by-step instructions on how to do that >with MoI v1.0 .
I am 100 % understand using the existing command ( relative & move command ).
>It would certainly not be bad to have more options for doing this in a way that is more familiar to you, and I'm going to look into that some more. But it is >definitely possible to get what you need currently without really any very great difficulty.
I just give you another idea that will help moi user more easy when they want to put an object in exact location ( i have post some GIF file before on this thread ).
If you have already used a parametric software like ( sw, pro, alibr....) before....., I think you will better understand what I want.
Thanks Michael, Keep spirit on your work for V2 !!!
1727.31 In reply to 1727.30
Hi Anis, how about this:
The way that works is that you first pick the base point same as regular move.
Then at the "Pick target point" prompt in Move there is a new option there - a button that says "Distance from edge".
Clicking that button will then pop up a "Distance" input where you can type in a distance value.
If you type in a distance value there, then when you pick the target point snapped on to a line, it will project the base point on to that line, and then place the target point at the specified distance away from that line.
Does that do what you need for that operation?
1727.32 In reply to 1727.31
Would we have to repeat the operation for the 'y' direction ?
To extend on that is it possible to make it so if we pick the intersection of the two curves and place x and y values in the box eg. 5,3.
1727.33 In reply to 1727.31
Thats exactly what I looking for.
I wish you will put this feature in V2.
Your support / effort for Moi User is Very nice.
I think its difficult to find another guy like you michael... :-)
Thank You !!!
Regards,
Anis
1727.34 In reply to 1727.32
Hi Danny,
Yup, that's correct. That seemed to be the same as the SolidWorks workflow that was shown where one constraint dimension is added at a time.
I was thinking a bit about making the command go in a loop to allow you to keep picking new distances and new edges without repeating the whole command. But then that would make you do an extra action to finish the command in just the simple case where you just want to apply one distance...
> the box eg. 5,3.
That's a good idea - unfortunately it is not quite so simple for me to set it up immediately because I don't have a control prepared that will take 2 distances in one edit box like that currently. I was actually able to do the one I showed pretty easily, that's why I was able to just crank it out right now.
There's also another problem with the 2 distance one - you aren't just limited to applying this distance to an edge in the x or y axis directions, you can do it to any edge currently. But with 2 distances I think that method would only work on axis-aligned lines because otherwise I wouldn't know which one to apply which distance to.
If you end up using this a lot and find that 2 distances at once would really speed things up, please let me know and I will try to dig into it more then.
For now it is easier to do the most simple way though, and we can see how that works to start with.
1727.35 In reply to 1727.33
Great! It actually did turn out to be easy to do with just kind of re-arranging the sequence to be more similar to how the Move command currently worked.
Yes it will be - that video that I showed was actually v2 in action there. So this will be in the first beta. It should be out pretty soon!
Please let me know if you run into any problems when you get a chance to use it.
One note - one thing that does not work is if your base point that you first pick is exactly on the target line that you specify next (like if the circle center was already directly on the line). It doesn't know which direction from the line it should move towards in that case.
Right now it will just switch to standard point-to-point move in this case, but you can use the regular distance constraint to move by a specific amount in this case already.
1727.36 In reply to 1727.34
Hi Michael....
Good idea michael, more & more faster...
Yup, i think this behavior is same in SW. When a the center of circle already connected with a line ( concident ), then we cant move the circle in a specific direction. Because the circle already constraint with the line.
No problem ( at least for me ).
Now, I am looking for your another work / idea on "object management / properties".
Maybe next week ???
Thanks Michael,
-Anis
1727.37 In reply to 1727.34
Yes, you're right, what you've done is good, if you could make the command go in a loop, that would be even better.
I was also wondering from going through this post is it possible to have a script or command to combine circle > position > extrude > boolean diff as a sort of one step hole function ?
1727.38 In reply to 1727.37
Hi Danny,
It's certainly possible, but it presents a pretty big UI challenge - so far I have tried to shy away from having too many operations that kind of duplicate other things that already have the basic "ingredients" available for them.
That's part of a kind of general effort to avoid UI bloat.
That would probably go in a category with some other operations like Rib, Boss, etc... It's better from a UI perspective to treat these all as a kind of batch set all together, which also kind of ups the bar for the amount of time needed to make them happen.
What I'd like to do before that is to kind of build up the ingredients another step more directly, like make it an option within the current Extrude command to do a boolean built in.
Show messages:  1-18  19-38  39-45
