Camera position and target
All  1  2-5
1715.2 In reply to 1715.1
Hi Marc, sorry there isn't any way to do that currently directly in MoI. You can retreive the direction of the view under Options / View / 3D view angles, but not currently the camera or target 3D point positions.
But if you save your file and open it in Rhino, you can use Rhino's "ViewportProperties" command to get at that info.
1715.3 In reply to 1715.2
yes but if you put all your objets at the center of a "big wireframe box"
I suppose then you press "Reset" you will have always the same view ;)
So now just make the same rotation view, Zoom (Rotate & Scale / the origin ) with any difficulty ;)
EDITED: 24 Jun 2008 by PILOU
1715.4 In reply to 1715.2
((But if you save your file and open it in Rhino, you can use Rhino's "ViewportProperties" command to get at that info.))
Thanks Michael, I think it will do the trick!
Thanks for the suggestion Pilou!
Marc
1715.5
I have done some preliminary testing and it's working, perfect corresponding!
Thanks again,
Marc
Show messages: All  1  2-5
