Can this be constructed as one object?
All  1-5  6-12
1714.6 In reply to 1714.5
Thanks again manz,
I got your example to work.
This was my original approach, except I was using just a single curve outline of my wave, extrude, then fillet. Fillet would fail due to the sharp point. I believe this is the issue Michael has illustrated a few times where the fillet diameter is bunching up and folding back on itself going around a tight turn.
So, it seems if multiple curves are used then larger fillet diameters work and they blend nicely where they overlap.
Very good. And, I learned a lot from using the network approach as well.
Ed
1714.7 In reply to 1714.6
Ok I'm missing something here. Was trying to follow along and I keep rounding off my sharps.
Seems as though I need to break something or add points?
Sorry if it is so basic. Help when you have time.
Burr
1714.8 In reply to 1714.7
Sorry, Figured it out. "Cap Ends" unselected left my peice with no sides. Now can continue to follow.
Burr
1714.9 In reply to 1714.1
Hi Ed,
>>The 2D illustration I'm using as a guide shows some beveling
I was curious if that could be easily created, so made some sweep surfaces.
I could then add a blend fillet on the top.
EDITED: 3 Aug 2009 by MANZ
1714.10 In reply to 1714.9
manz - you nailed it!
My experience so far has been building and slicing solids.
As far as constructing surfaces, it looks like you:
Selected 3 curves at a time. Joined two of them.
Swept the resulting two rails with a straight line profile.
Repeated the above for the remaining two surfaces.
Joined the three surfaces.
Fillet the center edges.
Is that the process?
Thanks again. A great learning experience.
Ed
Small is beautiful : simplicity is always the best :)
1714.12 In reply to 1714.10
Hi Ed,
You could build it by sweeping then boolean the swept surface from the extruded solid from profile. It can sometimes cause problems if the swept surface intersects itself within the solid, as that can cause failure. But as an example of creating that shape from slicing(boolean) from solid:-
We have the profile curves, I have the profile in 3 parts (which are for extruding the solid, and sweeping the surfaces to boolean), then have the profiles for the sweep positioned at the ends of the main profile.
Select the 3 main profile curves, and extrude to create the solid:-
I will first sweep along the top curve,.... so select the end downward facing sweep profile, and sweep along the top rail:-
Then boolean diff. The base object being the solid,... the object to subtract, the swept surface... You will only actually see the swept surface disappear when you boolean diff, that is because the surface that was used as boolean was open, so if you change view, you will be able to see that the solid as been sliced, you can then select the unwanted part and delete:-
Repeat that by sweeping the bottom 2 rails with the other end profiles and again boolean(slice) the solid, then delete the unwanted parts:-
If you where to instead just use surfaces, then you would sweep the profiles as you did above (sweep all 3), but rather than boolean them from a solid, you would use trim and trim away the unwanted surfaces.
Hope that helps, just ask if unsure or if I have not explained fully.
Show messages: All  1-5  6-12
