fillet trouble
All  1-10  11-19
1700.11
i'm trying, but I can hardly rotate the model when stuff hasn't even been joined yet :)
I really hope that multi threading will be a part of moi's future.
1700.12 In reply to 1700.11
Seems if you reload my model linked and joined, you will have no problem of rotation, I have not with my crazzy old one so...:)
1700.13 In reply to 1700.11
Hi telnoi,
There can be slowdowns due to graphics card, make sure you have the latest graphic drivers. You can also help with display speed by changing the settings in MoI: Options~ View~ Mesh Angle: increase for better performance (try 15 or 20), you can also disable the "Add detail to inflections".
- manz
1700.14
then I wonder what the difference is between your joined grid array and mine.
Even reloading doesn't seem to help :)
1700.15
@ manz, the strange thing is that I can load the finished model that has been posted here perfectly fine. However, when I join my model in my previous post and reload it everything becomes horribly slow. The model seems to be the same in this case..
I've been messing around with the view options, and do have it running fast enough. Still, the above is somewhat strange.
1700.16
"Mesh Angle: increase for better performance (try 15 or 20), you can also disable the "Add detail to inflections".
As manz mentioned, turning off the "Add details to inflections" really helps with any display slow down - saved my bacon just last week (on a relatively simple model too.)
-Will
1700.17
A similar issue. However, I don't understand why fillet is having issues with the R, especially since I have managed to fillet the other letters just fine. The odd thing is that I have managed to get fillet to react once, but never after using the same radius.
I have attached the scene.
1700.18 In reply to 1700.17
hi maybe a little trick
I have scaled x 10 the entiere model then made the fillet 0.2
I have not made the fillet base on this picture, but the fillet works also for the base!
(file 3Dm linked with base ;) (not unscaled / 10 !!! )
So you can "unscaled" / 10 at the end ;)
So I believe you work at a too little size scale of project unity ;)
EDITED: 16 Jul 2008 by PILOU
Size: 29.3 KB, Downloaded: 13 times, Dimensions: 540x334px
1700.19 In reply to 1700.18
thank you very much. That solved the issue :)
Now i can finally finish the model :D
Show messages: All  1-10  11-19
