Some other failled fillets ... (or booleans)
All  1-2  3-5
1698.3
Thanks a lot for the explanation, and for the tip ;)
1698.4 In reply to 1698.3
Hi PaQ - also one other workaround method is to use surface/surface filleting instead of edge-based filleting, the surface/surface fillet will be constructed in this type of situation.
To use surface/surface filleting, the objects involved must be individual single surfaces instead of joined-together objects. To get that you could select the 2 surfaces (sphere and the main body piece), then push Edit/Separate once to break that 2-surface chunk off from the main object, then push it again to break it out into 2 completely individual surfaces. Then you must deselect those objects and select each surface with a click - surface/surface filleting needs a click selection point on it to know which fillet to build in cases like 2 planes crossing over each other like an X.
That will build the fillet, then you can join those pieces back together.
Surface/surface filleting can succeed in places where the edge-based filleting will fail, the edge based calculations are more complex (but also more convenient because they know how to build corner pieces where different fillets meet).
1698.5 In reply to 1698.4
Excellent, I didn't know fillet can work in that way, with individual surfaces :)
Thanks a lot Michael !
Show messages: All  1-2  3-5
