Strange shell
 1-5  6-25  26-45  46-50
1693.6 In reply to 1693.5
arggg $5000 ... I can live without it for now :)
It's just that some weeks ago I tried to create some bottles design, something like the coke model, or any soft drink bottle ... so the outside of the bottle were easy
to create (with many booleans and fillets) ... but it was quite hard to have a good thickness for the inside part. So I was just asking myself what kind of software
they use for this.
I'll have a look to Viacad and Alibre, I'm really in love with nurbs now, so I want to explore and lean them a little more :)
1693.7 In reply to 1693.4
Can we do think that a concept of "good form" can be given by the nurbs like in the past hull boats drawing were given by flexible battens?
1693.8
Alibre Design Express is free..
1693.9 In reply to 1693.7
> flexible battens?
I'm sorry not quite sure what you are asking for here Pilou, are you looking for methods to automatically analyze a surface to see if it has a good shape or not?
You might try searching the web for terms like "Surface fairing" to try and find some more information on that.
1693.10
This is pretty normal I thought ?
I usually expect this, not only in MoI, so for something like this I would usually model the form longer, shell it then trim off the ends.
Hope this helps
1693.11 In reply to 1693.9
< are you looking for methods to automatically analyze
No no :)
Just in the artistic meaning!
If the fillet or sweep or ...don't work it's "a bad natural form", if yes it's a "good natural form" ;) as Golden Number etc ;)
(out case of impossibilities of course)
EDITED: 17 Jun 2008 by PILOU
1693.12 In reply to 1693.6
Hi PaQ,
I would agree with Michael and suggest you try ViaCAD as your companion with MoI for shelling puposes. This program
uses ACIS kernel as opposed to Solidworks Parasolid....but it seems very good in the test I did. Alternatively, if you are
like me and also use Rhino we should have Shelling in V5...maybe an early beta will do the trick for you.
Good Luck !!
Rgds,
--Paul--
1693.13 In reply to 1693.5
Hi Michael
I've been trying Spaceclaim LTX for Rhino, and find that to work well with shelling and filleting.
Think SC LTX not so expensive, and it takes the 3dm format in directly.
Do you know how SpaceClaim shelling compares to the shelling in programs like SolidWorks?
-Fredrik
1693.14 In reply to 1693.12
Hi Paul,
There is currently an open beta for version 6 ( http://punchcad.com/products/viacad2d3dv6.htm)
>>>Alternatively, if you are like me and also use Rhino we should have Shelling in V5
Have you ever looked at the "power solids/booleans for Rhino" from Npower? http://www.npowersoftware.com/rhino/proverview.htm just curious as that includes shelling
- manz
1693.15
NPower stopped support of their plugin after Rhino 3, so honestly that plugin is probably dead as doornails. As i mentioned earlier, i believe your rail curve has a little bend near the end. But you could also cap that object and then shell it in MoI, removing both end caps during the shell process. I think that would give you a decent shell...
jonah
1693.16 In reply to 1693.14
Hello Steve,
Yes I did try their plugin in V3 and then their shelling was hopeless !!! but that was before I actually had the need
for offsetting a complex polysurface for our water cooling design....there are so many apps available now with more
control on shelling such as different applying a different thickness to an area but not all...
ViaCAD looks interesting so far ;-)
Rgds,
--Paul--
1693.17 In reply to 1693.15
I was just curious. I use Rhino mainly for surfacing and have no need for booleans/shelling. I use other products for that.
Well, it is not my rail curve, but as you mention, having the "cap ends" enabled on extrude, then selecting the end caps for shelling would produce better results.
- manz
1693.18 In reply to 1693.16
Hi Paul,
I have looked at earlier version, but that was quite a while ago, I am currently downloading, but with slow feed from their site, so will take a look later.
I will also have a look at the latest release from Alibre when I have time (I have never used that before).
- manz
1693.19 In reply to 1693.18
Hi Steve,
First impressions are good and I think it would be another good partner for MoI. Nothing
beats MoI for its slick interface and speed of use and it's ability to swap data rapidly with
Rhino is critical for us.....were sold on these two but as far as shelling without spending
££££, ViaCAD looks really cool for that purpose.
Rgds,
--Paul--
1693.20 In reply to 1693.19
Hello there,
Well I have done a quick jump into viacad pro demo (15 days trial) ...
I get some trouble to import some 'simple' moi model, but I have to lean it a little bit more I guess.
For the moment it looks like I have to stitch every surface from the object because everything is separate ... and the stitch command return me
error messages ... so I can't really test the shell.
1693.21 In reply to 1693.13
Hi Fredrik,
No, I don't really know much specifically about that, but my general impression is that it is probably fairly close.
1693.22 In reply to 1693.20
Hi PaQ,
When importing the 3DM, select "Auto heal solids" in the popup
- manz
1693.23 In reply to 1693.22
Hello manz,
Auto healing failed :) ... but it seems I have a trouble in the moi object itself (I've just report it).
I did some shelling with some surface created in viacad, looks impressive so far (so are the fillets).
I will have some fun I guess :):):)
1693.24 In reply to 1693.21
I'm quite impressed by SC. The program is doing a good job on filleting and shelling. I tried it on some quite demanding things from rhino and it worked pretty well. Not everything worked completely fluently though. In some cases it got a bit comfused.
Took about 20 mins of fiddling before I understood the workflow, but then it was surprisingly easy. It seems to demand a fast PC, as even my super quad core pc was lagging behind a bit.
Anyways, SC handles consumed faces in fillets, and also moving features across surface boundaries (in most
cases, not all of course).
SW is history based however, which has it's advntages in some cases. But if you get the geometry from someone, history can be a constraint because you have to understand the sequence in which the model was made.
I think SC LTX is a companion of Moi if you are doing mecanical design. It's also good since it makes your model "live" in the sence that you can quickly move things around and fillet here and there.
It does not have nice G1, G2, G3 fillets like Moi, and not nearly the type of surfacing tools. So I imagine for product design, that the real shape design would be done in Moi, and then later you could edit it in SC and add the "mechanical details" to it.
-Fredrik
1693.25
Hello,
I have taken time to look at both ViaCAD and Alibre.
Alibre professional, I did have high expectations of this. After installation/ start up the UI looked very similar to solidworks/solidedge etc, so started to play. The first thing I noticed where the lack of surface tools,.. reading through the help files and rechecking the web site, I did note how they where really classing this product more of a companion for Rhino,.. (Rhino for the surfacing), there was a plugin for this, but it is only for Rhino3~3. I made a number of parts with various fillets etc and that worked quite well, the shelling was quite unpredictable in the selection of open faces, most of the time it simply would not select the face (add the face as open) so would be left with an hollow part with no open face, I got a little annoyed with that, so it is now removed.
Viacad pro. This does have many options for surfacing but have not yet found a way to produce a G2 surface, even the "net" surface appears to be based on sweep over multi rails, but will look further. The filleting was good and the shelling had no problems with the various parts I made. The only downside was the variable wall thickness option, which for selecting the face had to be done via a list (rather than selecting on model), that was a bit of a pain as it was a case of having to select through each named face in the list to find the correct one.
Personal conclusion,
I will give Alibre a miss (it does appear buggy), if I am going to be swapping between an application and Rhino, then that application will be MoI.
Viacad, This is a possibility, certainly as the Viacad 2d/3d ($99) does perform shelling, so it would possibly go well with MoI.
Just my opinion,
- manz
Show messages:  1-5  6-25  26-45  46-50
