Strange shell
 1-15  16-35  36-50
1693.36 In reply to 1693.35
I might be wrong, but i recall that version does not export Nurbs, only meshes?
jonah
1693.37 In reply to 1693.36
Yeh, I'm not sure about the PE version either jonah, but on their spec sheet it says...
>>Data Exchange
• Use imported designs as if native to CoCreate Modeling
• Import and export 3D via STEP, 3D IGES, SAT, and Printed Circuit Board IDF
• Export 3D as VRML and STL
• Import 2D via Autodesk DWG™ & DXF™, and 2D IGES
• Support lightweight publishing and viewing of eDrawings®
• Take advantage of automatic integrity check and repair
As I said, I'll have to investigate further, unless someone else has tried it already ?
1693.38 In reply to 1693.35
Hi Danny,
>>CoCreate Modeling Personal Edition (PE) is worth a try from PTC makers of Pro-E, they say the PE is free but I don't know if they mean, 'for free' or free download
It is Free, but requires activation (on each execution), so a need for the software to connect out to their servers each time it is run (it does allow 72 hrs "off-line" use)
You can import various formats, but the export is restricted, there is STL output~ But, that is limited to 1086 triangles, so not anything that can be worked with.
- manz
1693.39 In reply to 1693.38
Thanks Steve,
You saved me the research time, that I didn't have in the first place ;) I owe you one.
1693.40 In reply to 1693.29
>>I'm pretty sure that there aren't any formatting problems in MoI's IGES export.
EDIT:
I have had the models (I have been using for testing) checked in other Cad`s. There are no problems with the shelling of imported IGS files from MoI, apart from if the wall thickness is too big (greater than the minimal radius of curvature).
- manz
EDITED: 20 Jun 2008 by MANZ
1693.41
Hi all,
Just bumped into this after reading Michaels post about the MoI review in Develop3d mag.
Autodesk Inventor LT one year free license...................... http://labs.autodesk.com/technologies/inventor_lt/
Might be a good companion to MoI.
cheers
EDITED: 26 Jun 2008 by DANTAS
1693.42 In reply to 1693.41
hmmmmm interesting.
I wonder whats missing tho, I mean what can't LT do in comparision with big brother Inventor ?
Rgds,
--Paul--
1693.43 In reply to 1693.42
Hi Paul,
>> I wonder whats missing tho,...
According to the FAQ not much on the modeling side of things, not much missing that is.
Hope you don't mind the attachment Michael ?
EDITED: 27 Jun 2008 by DANTAS
1693.44 In reply to 1693.43
The free version includes one dozen aggressive sales calls from Autodesk... :)
jonah
1693.45 In reply to 1693.44
Thanks Danny....
Jonah: I wouldnt dream of leaving any contactable numbers ;-))
Rgds,
--Paul--
1693.46 In reply to 1693.41
I would of liked to of taken a look, but unfortunately the download/registration is limited to location :-
>>"Autodesk Inventor LT Technology Preview 2009 is available as English language software and is available for download only in Australia, Canada, France, New Zealand, and the United States"
1693.47
Wow! 1.3G download.
Not as lightweight as MoI :o
1693.48 In reply to 1693.47
It seems like lightweight has really gone out of fashion or something... :)
That is roughly 100 times the size of MoI's download.
1693.49 In reply to 1693.48
And that's 'Inventor LT', imagine how big 'Inventor Heavy' would be :)
And roughly 10 times the price when it goes to market.
1693.50 In reply to 1693.49
I got burned by Autodesk back in the early 90's when they came out with a product called "3D Concepts" - 3D programs back then were buggy and archiac by todays standards.
Anyway, the program was cool except if you boolean'd holes in your object it would display fine in the package but upon export the holes was missing!
Sent in several reports on this, it was never fixed, product dropped - just a quick program for them to rake in $250 to obtain some revenue and they moved on.
It looks like a powerful product but the idea is to get you hooked now, charge you later...
Caveat Emptor.
-Will
Show messages:  1-15  16-35  36-50
