Strange shell
 1-4  5-24  25-44  45-50
1693.25
Hello,
I have taken time to look at both ViaCAD and Alibre.
Alibre professional, I did have high expectations of this. After installation/ start up the UI looked very similar to solidworks/solidedge etc, so started to play. The first thing I noticed where the lack of surface tools,.. reading through the help files and rechecking the web site, I did note how they where really classing this product more of a companion for Rhino,.. (Rhino for the surfacing), there was a plugin for this, but it is only for Rhino3~3. I made a number of parts with various fillets etc and that worked quite well, the shelling was quite unpredictable in the selection of open faces, most of the time it simply would not select the face (add the face as open) so would be left with an hollow part with no open face, I got a little annoyed with that, so it is now removed.
Viacad pro. This does have many options for surfacing but have not yet found a way to produce a G2 surface, even the "net" surface appears to be based on sweep over multi rails, but will look further. The filleting was good and the shelling had no problems with the various parts I made. The only downside was the variable wall thickness option, which for selecting the face had to be done via a list (rather than selecting on model), that was a bit of a pain as it was a case of having to select through each named face in the list to find the correct one.
Personal conclusion,
I will give Alibre a miss (it does appear buggy), if I am going to be swapping between an application and Rhino, then that application will be MoI.
Viacad, This is a possibility, certainly as the Viacad 2d/3d ($99) does perform shelling, so it would possibly go well with MoI.
Just my opinion,
- manz
1693.26 In reply to 1693.25
Hello again
Maybe not!. I am now attempting to import models from MoI into Viacad, but on attempts to shell am being given error such as "Inconsistant faces" "bad curvature", this is from 3DM and/or IGS output from MoI. Some problems appear to be related to broken edges (which MoI does during booleans when overlapping seams) changing the orientation of the seams before boolean does stop the "inconsistent faces" on models with no fillets, but still problems with reported "Bad curvature" on filleted models.
I will need to find time to build the same models in Rhino to see if same error, but that will be a pain due to the amount/complexity of the fillets.
It may be a problem due to the import (format) as the same model created in Viacad does shell correctly, so I will need to check that as well.
- manz
1693.27 In reply to 1693.26
Hi Steve,
I have also had the same problem using IGES from our parasolid modeler - EdgeCAD into Shark FX
You cannot beat native geometry for complex calcs which is why models built in ViaCAD work better.
Like you I will be doing some tests with formats / method and will report back here next week so that
people can draw some conclusions what works well with MoI.
Rhino & MoI will always be ideally matched for obvious reasons....lets see if we cant add a third app to
complete the bundle for shelling (perhaps ViaCAD)
Rgds,
--Paul--
1693.28 In reply to 1693.27
Hi Paul,
I can understand some problems with 3Dm, but thought IGS would import with less later problems. I know different translators are being used Viacad~ 3d Interop and MoI~ Harmonyware, but would of thought better compatibility. Iges exported from Viacad do import back with no problem on shelling, so it just looks like formatting problems,.. maybe?
- manz
1693.29 In reply to 1693.28
Hi Steve, I'm pretty sure that there aren't any formatting problems in MoI's IGES export.
If you have an export that seems to be formatted incorrectly, can you please send me an example file so I can examine it and forward it to HarmonyWare if there are any problems in it?
Unfortunately it has just always seemed that ACIS based modelers have had some difficulties in data imports, that is not really a new thing. From what I've seen in the past, the ACIS kernel has some extra requirements on the kind of surfaces that it likes to use, it doesn't really like fully general surfaces it likes them to be parameterized in a certain particular way.
It's possible you may have better luck with SpaceClaim, I think that they have put more effort into file imports recently and particularly 3DM imports.
It won't be too far into v2 until I add in STEP and SAT format support as well, maybe ViaCAD has better support for those formats.
1693.30
Rhino has a "Reparameterize" command. Has anybody tried MoI-Rhino-ViaCad ?
jonah
1693.31 In reply to 1693.30
Hi Jonah - the Reparameterize command in Rhino can change the global UV extents of a surface, but parameterization has other factors in it as well like how it is spaced as your travel through the knot vectors of a surface, not just on the overall scale value.
If I remember right, ACIS is mostly sensitive to the kind of internal parameter spacing and how closely that matches spacing along distances in 3D. The Reparameterize command does not change that kind of internal relative spacing.
But I guess you never know - maybe it would help. If it does then it would certainly be a good idea for ACIS / ViaCAD to incorporate that UV scaling into their importer so that they could handle general NURBS surface inputs instead of ones that happen to have a certain structure.
1693.32 In reply to 1693.29
I was thinking the format output by MoI/Rhino is no good for Viacad, well, that is obvious, not that the IGS output from MoI/rhino is bad/corrupted.
mmmm, well, from the comment from Fredrik put together with the fact there is no "product capabilities" (well apart from file import/export), that there is no price on the Pro version (which is the only version available for download) there is also no comparison chart of the difference between the Pro and LT versions, and the fact the LT version is priced at £595 (GBP), it make me think Spaceclaim is another Alibre professional, "looks good, but very little under the hood for the price"
The Step from Rhino does import and shelling made, but I have only looked at simple models (but even those where failing with 3DM/IGS)
The (Acis) SAT from rhino showed problems (check object), but I have not checked all the various output types yet.
- manz
1693.33 In reply to 1693.32
Well well well, looks like it's quite complex just to have a 'better' shelling command :).
I did some .igs export test in Viacad, works fine so far (but it was simple objects). However it's true the shelling wasn't working
so good when objects are not created in viacad itself ... I suppose the construction history might help to resolve complex overlapping surface.
Well I thing I'll give up for the moment, as it requires to much technical knowledge and I don't have the time (I'm a bit lazy when it's about
reading documents).
Looks like the first best friend for Moi is still Rhino (maybe not for the shelling), I hope I will find some job soon where I can use all I've learned
so far in Moi, and pick a Rhino license (a bit expensive for an hobby style of work)
1693.34 In reply to 1693.29
Well I look forward to that, not for ViaCAD but to go 'direct' into my CAM system.
I might look at Spaceclaim LTX because it is supposed to have full .3dm support, I will
have a look once I have covered everything in ViaCAD.
Rgds,
--Paul--
1693.35
Hi Group,
Just thought I'd pop in.
CoCreate Modeling Personal Edition (PE) is worth a try from PTC makers of Pro-E, they say the PE is free but I don't know if they mean, 'for free' or free download,
you have to register to find out. Anyway to come to the point, in the feature list they mention 'Advanced shelling' so when I have time I will investigate.
1693.36 In reply to 1693.35
I might be wrong, but i recall that version does not export Nurbs, only meshes?
jonah
1693.37 In reply to 1693.36
Yeh, I'm not sure about the PE version either jonah, but on their spec sheet it says...
>>Data Exchange
• Use imported designs as if native to CoCreate Modeling
• Import and export 3D via STEP, 3D IGES, SAT, and Printed Circuit Board IDF
• Export 3D as VRML and STL
• Import 2D via Autodesk DWG™ & DXF™, and 2D IGES
• Support lightweight publishing and viewing of eDrawings®
• Take advantage of automatic integrity check and repair
As I said, I'll have to investigate further, unless someone else has tried it already ?
1693.38 In reply to 1693.35
Hi Danny,
It is Free, but requires activation (on each execution), so a need for the software to connect out to their servers each time it is run (it does allow 72 hrs "off-line" use)
You can import various formats, but the export is restricted, there is STL output~ But, that is limited to 1086 triangles, so not anything that can be worked with.
- manz
1693.39 In reply to 1693.38
Thanks Steve,
You saved me the research time, that I didn't have in the first place ;) I owe you one.
1693.40 In reply to 1693.29
EDIT:
I have had the models (I have been using for testing) checked in other Cad`s. There are no problems with the shelling of imported IGS files from MoI, apart from if the wall thickness is too big (greater than the minimal radius of curvature).
- manz
EDITED: 20 Jun 2008 by MANZ
1693.41
Hi all,
Just bumped into this after reading Michaels post about the MoI review in Develop3d mag.
Autodesk Inventor LT one year free license...................... http://labs.autodesk.com/technologies/inventor_lt/
Might be a good companion to MoI.
cheers
EDITED: 26 Jun 2008 by DANTAS
1693.42 In reply to 1693.41
hmmmmm interesting.
I wonder whats missing tho, I mean what can't LT do in comparision with big brother Inventor ?
Rgds,
--Paul--
1693.43 In reply to 1693.42
Hi Paul,
>> I wonder whats missing tho,...
According to the FAQ not much on the modeling side of things, not much missing that is.
Hope you don't mind the attachment Michael ?
EDITED: 27 Jun 2008 by DANTAS
1693.44 In reply to 1693.43
The free version includes one dozen aggressive sales calls from Autodesk... :)
jonah
Show messages:  1-4  5-24  25-44  45-50
