MoI to Modo - problem with anisotropic reflections?
All  1-14  15-18
1690.15 In reply to 1690.14
Hi Jonah,
> Do you also want the Modo test file?
Sure, that certainly might come in handy for testing as well.
If you did have a big n-gon at the top there with the MoI export, then that is most likely to be the single biggest difference between the Rhino export and the MoI one. That would mean that Modo wants to have an actual poly vertex at that central spot to make it work correctly, it is otherwise trying to some kind of interpolation across a polygon which is not working right. Right now that is kind of my best current guess but not verified of course.
1690.16 In reply to 1690.9
Hi Ed,
>>I use Hypershot for my renders. It is still a relatively new product and requires that UV coordinates come in with the import.
I use Hypershot also, but have had no problem so far. I always export the model as .obj from MoI, because no matter what Hypershot allows you to import it always converts it to .obj.
1690.17 In reply to 1690.11
Hi jonah,
>>It is a legitimate problem.
It sounds like Modo is a pain on this point.
Can a 3rd party mapper, such as UV-mapper help? http://www.uvmapper.com/ (there is a free version)
1690.18 In reply to 1690.17
Thanks for the suggestion. But I'd rather not have to do any mapping at all. In that case, I'd rather just export from Rhino. Let's see what can be resolved using software which I already use... Modo actually has some nice UV tools, but missing something to handle a "revolved" disc...
jonah
Show messages: All  1-14  15-18
