Does scale matter?
All  1-5  6-11
1688.6 In reply to 1688.5
>>yeah you should generally create models in MoI with a size of like somewhere between 0.1 to 1000 units, and generally try to avoid very much smaller or very much larger than that.
Is there a problem if I modeled something to scale that is 3 meters long ?
1688.7 In reply to 1688.6
Hi Danny, you mean a size of 3 meters, where you are using meters as units in MoI?
There isn't just one single answer to that - it depends on the size of the smaller details in the model. I guess it should actually be ok to go down about 0.01 units for a size of a feature but not too much much more down than that.
So if your 3 meter object has details in it that are smaller than 1 centimeter in size, you will probably need to model it with centimeters as units instead of meters as the units.
But if your 3 meter object has details in it around 1 centimeter or larger in it, then that's fine.
1688.8 In reply to 1688.7
What if I was modeling the 3 meter object in mm (3000mm) and it had 1mm details ?
1688.9 In reply to 1688.8
Hi Danny - that should be ok I would think. You're going to get calculations that keep working until they get to an accuracy of 0.001 mm in that case, which is kind of too accurate - it will tend to cause somewhat larger sized files with more control points in intersection curves than are really necessary.
If you go very much larger than that, then that problem gets to be more and more magnified where things that are fit to tolerance just get to be too dense because 0.001 is too tiny in comparison to the objects being constructed.
I would like to try and tweak this system in the future sometime to be more adaptive to the size of the objects being built, but it is a pretty complex and sensitive area to mess with.
I guess my ideal recommendation for something of that size would be to do it in centimeters and have values that maxed out with numbers like 300 and details at 0.1, that would be somewhat more optimal from a file size / complexity kind of standpoint. But it is not like doing it mm would be a disaster, just something like 20% larger file or something like that maybe.
1688.10 In reply to 1688.9
Ok, So if I model scaled down, say 1:10 of the size I want, then after finishing that model could I scale it to actual size for export ?
1688.11 In reply to 1688.10
Hi Danny,
Yup, that would work fine.
If you have your units set (under Options / General / Unit system) to Centimeters, then you can scale your model before exporting by just switching that to Millimeters - that will do the scaling for you unless you have turned "Scale on unit system change" off under Unit options.
You can also scale everything to a particular scale factor by using Transform/Scale. To do that, select all objects, run Transform/Scale, type in "0" <enter> to pick the 0,0,0 origin point as the scale origin, then type in your scale factor for example 0.1 to scale by 1/10.
Show messages: All  1-5  6-11
