Which version of AI on File-Import list?
All  1  2-5
1687.2 In reply to 1687.1
Hi angeliclight, MoI should be able to read in Adobe Illustrator CS3 files, I just recently tested a couple that worked fine.
Do you have an example that does not work properly? If so then can you please send it to me at moi@moi3d.com, so I can take a look?
The AI file format did change quite a lot after AI version 8 (8 or 9 I think, I forget which one exactly), to become based off of PDF which is much more complex than the old style file format. So if you do run into problems it is likely that using an AI version 8 or lower type file would work more smoothly.
But I do want the newer PDF style format files to work as well, so if you do have problems please let me know.
1687.3 In reply to 1687.2
Honestly,
I haven't gotten started on importing anything yet, but Corel mentions that they export like v9 or something, so I just wanted to make sure before getting started that there wouldn't be any sort of compatibility problems that I'd falsely blame on any of the software involved. :)
Thanks very much!
- A
1687.4 In reply to 1687.3
Illustrator CS3 gives all these AI file options.
I tend to allways save as the Legacy 8 as this seems acceptable to most apps.
Brian
EDITED: 31 Dec 2008 by BWTR
1687.5
Thank you very much!
Show messages: All  1  2-5
