component system......(moi and Sketchup!)
All  1-2  3-7
1676.3
Thats great news Michael !
You can see this kind of thing is very usefull !
I´m thinking about array on surface etc.
Peter
1676.4 In reply to 1676.3
you can make obj file with the free GoogleSketchup with a little trick;)
export it as KMZ file now reload it in the free Blender for example with this script inside the folder Scripts
and now save it as Obj file ;)
http://jmsoler.free.fr/didacticiel/blender/tutor/py_import_kml-kmz_en.htm
EDITED: 10 Jun 2008 by PILOU
1676.5 In reply to 1676.3
Hi Peter, that will kind of work in the first v2 beta with planar surfaces, because a whole bunch of commands including array are able to use a plane surface's orientation if you snap picked points on to them.
For example here is a circle that I drew on an angled (non-world axis aligned) box, then used Array:
Because I snapped the array unit cell rectangle on to the plane there, it used that plane's orientation for the array command instead of the viewport's construction plane like it normally would.
This kicks in with a whole bunch of commands that get planes as part of their input, like circle drawing, rectangle drawing, .... that happens to include array as well.
I still need to do a few tune-ups to this, it is a pretty wide ranging change that affects a lot of stuff.
In the future I do want to have a specialized "Array on surface" command as well, but it will be focused more on arraying along curved surfaces, for planar surfaces doing the above or setting a custom cplane and using the regular array grid would be the way to do it.
1676.6 In reply to 1676.1
And sorry if I gave the wrong impression about components earlier - I definitely want to have all the snapping type capabilities for that in v2.
It's just the whole kind of organized system with a browser and stuff like parts keeping their identity as a component so that they can all be changed by editing the base definition, stuff like that will take longer.
The basic function of applying an object snapped on to a planar surface will happen before that.
1676.7
thats perfect !
thats the most important part of it !
That helps a lot for doing things I want to do !
peter
Show messages: All  1-2  3-7
