Transform>Array
All  1-2  3-10
1668.3 In reply to 1668.2
Yes - Thx!!
Rgds,
--Paul--
1668.4 In reply to 1668.3
Hi Paul, I've also now fixed up v2's array grid to work like you were originally expecting - now if you set 1 item in either the x or y directions, it will only have an input box for x spacing or y spacing instead of both (however, drawing the spacing with a mouse will still use a rectangle).
1668.5 In reply to 1668.4
This may already be on the wish list, but can we have the array distribute (or divide) over the selected distance, as well as increment (multiply) which is what it currently does?
1668.6 In reply to 1668.4
...Just noticed this post. Thank's Michael !!
If we could have a preview tick box and a BACK button below the 'axis spacing this would make it more flexible
as a command with the ability to see and change without leaving the cmd......just a thought ;-)
Rgds,
--Paul--
1668.7 In reply to 1668.5
>> From: buzz (BRUCE) 9 Jun 10:59 (5 of 6)
I second this!
Tony
1668.8 In reply to 1668.5
Hi Bruce, yup I already have that one on my todo list, to make an option for array grid and array dir to define the full extent instead of the incremental extent.
1668.9 In reply to 1668.6
Hi Paul,
Hmm, unfortunately these ones are a bit difficult to add without making array stick out and behave differently than other commands.
I've generally tried to avoid having a special "preview" button in MoI - instead it just automatically does previews when it can. Array grid tends to be a potentially rather "heavy" case though since it can create quite a large number of objects... So to keep it running smoothly in all cases it does not currently do a preview. Maybe in the future I could do something like detect when it is going to make less than 30 objects or so and go ahead and do it dynamically then.
re: Back button - that is also a good idea, but it is something that I would probably want to go in and add into every command, not just one single one. But of course that is a lot of work so it might take quite a while before I can gather up time to do that.
1668.10 In reply to 1668.9
Once you have a wireframe display mode, you could use that for array preview. Or maybe just use bounding boxes to represent the clones...
jonah
Show messages: All  1-2  3-10
