Make Surface
 1-20  21-26
1665.21 In reply to 1665.20
jonah
I can't get over how difficult this particular shape is.
I tried making it in several of my other subD and Nurbs apps also and MoI is WAY ahead!(Well I could not do it in any of them!)
What is it in this shape especially that creates problems I wonder?
Anyway, for use in my normal 3D rendering apps I at least got a fine result eventually---with thickness!
(What a time waster!)
Brian
EDITED: 31 Dec 2008 by BWTR
1665.22 In reply to 1665.21
You should be able to create the surface in other applications even poly apps, for example, I created the surface in Hexagon from the line data (the other poly programs would not import the line data, so did not attempt).
In MoI/Rhino you would build using "network", in poly programs you would use (as in Hexagon) "Gordon surface". I am not saying the resulting surface would be accurate enough for machining, but it can be easily modeled from the curves given.
- manz
1665.23 In reply to 1665.22
Manz
1.Are you saying you created the same lines in Hexagon and enabled Gordon surface to them.
2.and/or you imported the line data to Hexagon in "?format" (from?)and enabled Gordon surface to the lines
Is it a Brian day? I can not do either!
Brian
1665.24 In reply to 1665.23
I converted the line data into DXF then imported into hexagon, I did have to weld some lines/curves to create the correct lat/long sections needed.
- manz
1665.25 In reply to 1665.24
Thanks.
What a complex world!
Brian
1665.26 In reply to 1665.25
Unless you purchase MoI of course :-))
Rgds,
--Paul--
Show messages:  1-20  21-26
